Toshiba lt170 wont turn on, no light, cord is perfectly fine i used it to charge my phone butwhen i plug it into the tablet it wont do anything
  • 3 Answers
Then you have either a bad battery or bad connector on the tablet. It is also possible although less likely that the power button does not work.
Posted on Jan 18, 2013
If you know for sure the cord is good, make sure the battery is. If the battery checks out, most likely is a bad connection port on the tablet itself. normally caused by a cold weld.
shaky120
  • 310 Answers
SOURCE: Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Hey, definely sounds like the power jack is your problem, i have seen many companys including ourself soldering on the jack, but there never the same, ie easilly broken off again.
i dont think your power jack is making direct contact, i know you can move it about till u get the charge.
but i would say thats your fault..
Sorry i cant help more
Have a good new year
John
Posted on Dec 29, 2007
steve6375
  • 395 Answers
SOURCE: Toshiba Satellite A105-S4064; can't get battery to charge
If you put strain on the jack (e.g. hang power adaptor from it whilst using or charging) then the socket on the mainboard can get hot due to poor contact and melt.
There is no way to fix this except to completely dismantle the laptop and fit a new socket - most likely a repair centre will charge you for a new mainboard.
Try another adaptor to see if that is the problem (broken wire in cord) - otherwise look closely at the socket in the notebook.
Posted on Aug 08, 2008
djtatty
  • 417 Answers
SOURCE: my toshiba wont always charge properly, itll say
Try checking the power management settings in control panel.
& if there all set correctly, Then take the battery out & plug in the charger.It should run on it's own.
If it doesn't the chargers gone, but if it does run then put the battery back in whilst it's still on. If still no joy then wiggle & bend the cable from top to bottom & all the joints to check for breaks or bad connections, But leave the laptop switched on so that you can hear it bleep every time you hit a fault.
GOOD LUCK if you get stuck contact me for free advice...
Posted on Sep 04, 2009
RescueTechLA
  • 2653 Answers
SOURCE: my toshiba satellite m305ds4831 laptop will not
It's a motherboard hardware issue in all likelihood.
There is NOTHING you can do but update the firmware bios. The problem is that most bios firmware update programs require both ac and battery power at the same time :(
You can try to do it anyways by visiting Toshiba's support page for your model and downloading the firmware from there.
It probably won't fix the problem but it's still worth a shot....sometimes it works ;)
Posted on Nov 21, 2009
  • 5 Answers
SOURCE: laptop wont power up HP-Compaq
It sounds like you need a new battery. They do go bad over time. You can probably find a replacement at a battery store or an office supply store. That way, you can try it out and make sure that is the problem. If replacing the battery doesn't fix your problem, you can always return it to the store (or just keep it as a spare).
If replacing the battery doesn't solve the problem, then there is most likely a problem with the port where the power connector plugs in to the laptop. You'll want to contact the manufacturer about that kind of repair, though some local shops might be able to do it.
Posted on Feb 28, 2011
Why wont my nextbook flexx 11 charge or turn on
Take it to a repair shop!!! Never use the wrong charger on computer equipment. Damage can occur.
Sep 03, 2017 | Nextbook Tablets & eReaders
Why wont my Samsung Galaxy tab 3 notcharge past 60%
The battery may be unable to charge to more than the 60% level.
Oct 07, 2016 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My tablet wont charge or turn on.. I have replaced the power cord cause a friends dog chewed up mine.. it work just fine till I replaced the power cord
Hi. Can you post your tablet's model part no.? It looks something like this near where you'll find the serial no. --> PDA01U-00101F
Apr 12, 2015 | Toshiba AT100-100 TABLET THRIVE
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
I bought a Bamboo Splash a while back, and it had been working fine up until today. I sometimes unplug my tablet and use the cord to charge my phone. Today when i disconnected my phone and put the cord...
Unplugging the tablet would not hurt it in anyway. A power surge can cause such a problem though. Typically the problem you are describing is caused by bad flash memory which is what all tablets use and run on Like a....Example: A Solid State Drive "SSD"
Nov 09, 2013 | Wacom Bamboo Splash Pen Tablet
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
My laptop will not turn on and will not charge. The little light on the far left (looks like a plug in cord) is blinking, but the charging light does not come on when I plug the charger in and it will not...
You will need to purchase a new Power Supply Unit if it is not able to start up when it is plugged in the PSU is bad. Replace the unit immediately. I hope this assisted you. You can find them reasonable at Amazon.com this is where I purchase customers units at. Thanks for using FixYa for all you questions. John
Feb 12, 2011 | Toshiba Tecra M7 Tablet PC
Toshiba satelite r15-s822 will not power up
Take the battery out and try starting it with just the power cord plugged in.
Sep 25, 2008 | Toshiba Satellite R15-S822 Tablet PC
Bamboo Fun usb device not recognized
Change the USB cable... this is the problem...
Sep 22, 2008 | Wacom Bamboo Fun USB Tablet with Cordless...
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
Computers & Internet Logo
379 people viewed this question
David Payne
David Payne
