Question about Konica Minolta bizhub Office Equipment & Supplies
Solution for konica 351 erer code c-0098 - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Expert
  • 337 Answers
Fuser drive error. check the pressure/retraction gear on the fuser.
Posted on Jan 30, 2013
Upgrade Konica bizhub 351 firmware
Firmware is only available thru a secure konica minolta web site must have a tech do it.
Jul 21, 2015 | Konica Office Equipment & Supplies
Erer oe
The LG error code OE simply means "the pump is blocked".
Jun 09, 2014 | Washing Machines
Error code c 0098
no such code for that modle Bizhub 350
Jan 29, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Minlota Photocopier Di Alta Di 351 Broblem code CO510 COULD YOU PLEASE ADVISE ME WHAT IS THE PROBLEM WITH MY PHOTO COPIER AND WHAT COULD BE THE SOLUTION
Hello the problem you have with error code c0510 is caused by the fuser unit the best thing to do is to replace the fuser unit also make sure you have the most up to date firmware installed on the machine
Feb 02, 2011 | Konica Minolta Office Equipment & Supplies
What is it when display reads malfunction code C2654 on a Konica 351 copier?
C2654 code means Black Imaging Unit eeprom access error.
A condition of "EEPROM is not connected" or
"There is an access error" is detected in
EEPROM of the Imaging Unit.
So the issue lies within your Black Imaging Unit. I would try sliding the imaging unit out partially, then re-installing. Reset by switching off the main power.
If this does not solve the error then you will need to call your local service provider.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 29, 2010 | Konica Minolta DiALTA Di200 Copier
Error code C-0211 Konica Minolta Bizhub C-351
It's called "Manual Bypass paper lifting failure". The manual says to check Tray 2 vertical transport motor. Check the wires to see if the are okay. Pull out tray 2, remove back cover, remove wire assembly from 4 wire saddles, remove 2 screws and the motor assembly. The should be 2 motors on the assembly and the one u need to look at is the bottom one. hope this helps.
May 22, 2009 | Konica Minolta bizhub C351 All-In-One...
MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Mar 07, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Printer & scanning Driver for Konica color 8022
I believe that machine uses the same print controller as the Bizhub C350. You will have to verify this - it's an optional unit attached to the rear of the machine. It will be where your network wire plugs in. It "should" be a IC-401 model print controller. That's the driver you need from Konica.
Feb 21, 2008 | Konica Minolta bizhub C250 All-In-One...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
