Question about LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive
LACIE LC3U2 FORMATTING DRIVE F DRIVE G OK
Format problem with Lacie portable HDD
Format the drive using another utility then delete the partitions on the drive and try again
Aug 17, 2012 | LaCie Rugged All-Terrain (301017) Hard...
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
How do I erase my LaCie hard drive?
Open "My Computer"
Right-mouse click on the icon for the drive
Choose "Format"
Choose "Quick Format"
Click "OK"
Feb 21, 2011 | LaCie Computers & Internet
Trying to drag all files from itunes into lacie 250 g design by porsche hard drive and it won't let me.
Thank you for asking your question with FixYa Support.
I am not sure what type of computer you have that your LaCie is connected to, but first and foremost, make sure the external hard drive has been properly formatted to work with the operating system your computer has.
For Windows computers: the LaCie should be formatted in either FAT32 or NTFS (recommended- more secure).
How to Format a HD in Windows Vista
For Mac computers: the LaCie should be formatted in Mac OS Extended (Journaled) format.
How to format an external hard drive in Mac OS X
If your LaCie is already formatted, then the best way to import your entire iTunes library from the internal hard drive of your computer into the LaCie, especially if you are unable to drag and drop the library into you LaCie, is to try a simple copy and pasting of the ENTIRE iTunes folder from its home on your computer to the LaCie hard drive.
You can also use the website I like to reference which provides some good alternatives to effectively migrating your iTunes Library from a PC or Mac to your external hard drive:
Here is that support link:
How to Transfer iTunes Library to another Computer
(also included in this article, are external hard drives)
For sake of space, I want you to review this article, because I not only agree with its content, it is exactly what I would explain to you as well in a more condensed, easy to follow fashion.
I hope I have helped guide you well on your question.
Regards,
-Mactechtrainer
Mar 28, 2010 | Computers & Internet
I need to download the LACIE setup assistant and can't find my software. Does anyone know where I can find this program to download. I need to format my Lacie drive for windows. Thanks if some one can...
The webpage of LaCie support doesn't have the "LaCiee Setup Assitant" program. And LaCie Backup Assistant is another program. Can't you guys read? He asked for another program!
So you did not help!
I need it too, but it seems impossible to find,
Cheers!
May 31, 2009 | LaCie Big Disk Extreme with Triple...
Lacie usb floppy drive won't format a disc
on the floppy disk there should be a little switch push it across
now put in right click options format
Jan 14, 2009 | LaCie Pocket Floppy (706018) External...
How to format the LaCie 500GB d2 Quadra for Windows XP??
This way it should work...
Connect your drive to the computer...
Go to: Start > Control Panel > Administrative Tools > Computer management.
A new window will appear...
Select Storage > Disk management on the left of the window.
Now you will see the different drives that are connected or part of your system.
One of the drives listed there is your LaCie, i think you'll recognize it by name...
Right-click on it, and select 'format'
In the new window, select the new volume label (as you like it), the file system (use NTFS), and set allocation unit size to default.
Make sure 'Perform a quick format' is not checked...
Then click OK. Your drive will be formatted now... Don't interrupt the process
Mar 31, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive mysteriously went from 250GB to 55MB!?
Hi, It would seem that the LaCie(300770) 250 GB Hard Drive would need partitioning and not only formatting to be able to recover the missing space. This is better explained by Microsoft Support . Alternately, you can right click on "My Computer, click on Manage, click on Disk Management, right click on the Lacie drive and delete its current partition. Ok or Apply, Windows may ask you to reboot. Do the Disk Management again. If the Lacie's original/erroneous partition has been successfully deleted, it will now show as "Unknown Partition". To create your new partition, right click on the unallocated space (black stripe on top), click on "New Partition" on the menu. To format, simply right click on the Lacie and click on Format. As a matter of choice, I prefer to use Partition Magic and/or Seatools for Windows. If using any of the above method and the Lacie will not partition/format or errors keep on appearing, it may be that the Lacie is no longer usable as a whole. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 27, 2007 | LaCie (300770) 250 GB Hard Drive
LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive Logo
515 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
