Question about Ricoh Aficio 2015 Copier
When i make a copy, it shrinks in the sub-scan magnification
How to copy legal to letter on copystar CS 4005i
Make sure your default settings are for AUTO paper selection and 100% magnification to start. That is the most common default settings. Then, under "Zoom" change to AUTO magnification and under PAPER SELECTION specify Letter (either landscape or portrait). Now when you copy a legal original (8.5" x 14") it will be reduced at 78% to fit it on an 11" sheet. An alternative is to use "X-Y" zoom. Now you can stipulate 78% for the "X" dimension and leave the "Y" dimension at 100%. You will want letter size paper to be feeding lengthwise (portrait). Now you can copy legals and the image is reduced top-to-bottom only, leaving it much more readable.
Mar 16, 2015 | Copystar Office Equipment & Supplies
Tip
The Easiest Way to Use DVD Shrink
<b>DVD</b> <b>Shrink</b> is a freeware DVD transcoder program for Microsoft Windows that uses a DVD ripper to back up DVD movies. The final versions are 3.2.0.15 (english) and 3.2.0.16 (german), all other versions like DVD Shrink 2010 are scams. As commercially-released video DVDs are typically dual layer one of DVD Shrink's functions is to process the video into lesser quality and/or discard extra content such as foreign-language soundtracks so as to fit on a single layer (4.7 GB) DVD.<br /><br />DVD Shrink is freeware, and it is only to be used to create backup copies of DVDs you already own. It is illegal to make copies of rented or borrowed DVDs, or to copy them and sell them for profit. The reason we need DVD Shrink is because a regular DVD movie doesn't fit on the average 4.7gig size DVD disc, we <b>use</b> DVD Shrink to cut the contents down to size as to fit on the disk.<br /><br />This article will provide you <b>how</b> can you use DVD Shrink to copy DVD movies step by step. All you need is a DVD Shrink software and you will be able to store and duplicate all your DVD discs.<br />To use DVD Shrink, Things you will need:<br />* DVD Shrink program <br />* A DVD movie to backup<br />* DVD blank disc<br /><br />Guide: How to Use DVD Shrink 3.2 <br /><br />Step 1. Start the DVD Shrink Program and choose Open Disc from the menu above. <br /><br />Step 2. A box will appear. Choose which DVD drive your disk is in. Mine is in F: drive. The name of the disk will show up in brackets. In this case it is called NEW. <br /><br />Step 3. Press OK. It will read the DVD.<br /><img src="remote_image20110803-18141-1qmdivp.gif" /><br />Step 4. Shrink DVD size.<br />1) A breakdown of the movie will be displayed in the right hand column.<br />2) You cannot fit all this on your blank dvd so now press Re-author.<br />3) In the right column there will be a heading called Main movie. There will be a file under this heading. Drag this to the left column. The file size is usually more than 4,700mb and has to be compressed.<br /> <img src="remote_image20110803-18141-17xn34v.gif" /><br />Step 5. Click on the "Backup" icon. This is where you will choose a folder for your ripped files. Once you make a folder, make sure the box is checked next to "Create VIDEO_TS and AUDIO_TS subfolders" and click "OK".<br /> <img src="remote_image20110803-18141-sc8anv.gif" /><br />The movie will now play quickly in the viewing box, and you will see the progression of the rip. Once the rip is complete, the movie can be burned to a DVD-R automatically via DVD Shrink using NERO. Or if you have different DVD-burning software, you can open that manually and burn the ripped files as you normally would.<br /><br />Here we also recommend you the best DVD Copy software, 1CLICK DVD COPY PRO, which is a fast, easy-to-use, full featured program for copying DVD movies onto DVD discs. With 1CLICK DVD COPY - PRO, you can make a perfect copy with just one click. You can free download DVD Shrink via the link below:<br /><br />Tags: how to use dvd shrink,how to use dvd shrink 3.2,how to use dvd shrink to burn a dvd,dvd shrink free download,free dvd shrink,shrink dvd software<br /><br />Related Resources: <br /> <p><span><a href="http://www.dvdcopymac.org/burn-dvd/burn-movies-to-dvd-on-mac.html"><span>burn movies to dvd on mac</span></a>,</span><span> </span><span><a href="http://www.dvdcopymac.org/">dvd copy mac</a>, <a href="http://www.dvdcopymac.org/resource/free-dvd-copy.html">dvd copy freeware</a>,<a href="http://www.dvdcopymac.org/burn-dvd/convert-burn-m4v-to-dvd.html"> m4v to dvd</a>, <a href="http://www.dvdcopymac.org/guide/how-do-you-copy-a-dvd-in-windows-7.html">copy dvd in windows 7</a></span><br />
on Aug 03, 2011 | Computers & Internet
My machine is showing me p-22 what does it mine
Color regist adjust failure
• The color shift amount is greater than the specified
range during main scan direction registration correction.
range during sub scan direction registration correction.
• On the color shift test pattern, the maximum and minimum
deviations detected in the main and sub scan
directions go over the predetermined value.
Dec 23, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Aficio 1232c erreur 122
SC122
[Cause]
SDRB board is faulty.
[Resolution]
Replace the SCRB board and ground.
AND
SC122 occurs while scanning.
Does not occur when scanning at the same magnification; occurs when copying and enlarging.
[Cause]
Scanner motor is faulty.
[Resolution]
Replace scanner motor.
And one thing to check is to make sure the set screw that locks the cable pulley to the scanner drive shaft didn't back out or shear off.
Sep 22, 2011 | Ricoh Aficio 1232C Color Copier
Sharp AR 507 has a code L3-00 Scanner will not retun home in time
I turned the copier off completely, then turned it back on -- it seemed to resolve the L3-00 issue.
Apr 30, 2009 | Sharp AR-507 Copier
How do i use this?
Sharp SF2414, Сode
CH If lit steadily, paper feed section cover is open or manual feed unit not installed properly. If flashing, developer seal still installed, or toner density sensor/main board problem. EE Sub code EU: undertoned. May be toner density sensor problem or developer unit problem. Sub code EL: Over toned. May be toner density sensor problem or developer unit problem. H2 Sub code 0: Fuser thermistor. H3 Sub code 0: Fuser temperature too high. H4 Sub code 0: Fuser temperature too low. L1 Scan problem. Sub code is 0, but there is no more detail. Could be no scan drive; scan did not leave home; scan did not return home; scan overloaded; mirror motor problem; scan cable came off. L3 Scan return problem. Sub code 0. Approximately same causes as L1 L4 Sub code 1: Main drive problem. Sensor, gear, motor. L5 Sub code 2: Lens drive, motor, sensor. L8 Sub code 1 Power frequency varies by more than 5 % or for more than 5 sec. Sub code 3: AE sensor problem. PC Key counter not installed. SPFJAM Document feeder problem. U2 Sub code 1: Main board EEPROM problem. Sub code 4: Memory problem. U5 Sub code 5: high temperature at exposure glass when using document feeder
Apr 03, 2009 | Sharp Office Equipment & Supplies
Cuts off left hand few letters in a word
Either put the paper closer to the other side of the glass, or go into the settings to see if it is copying or scanning at 100% See if gives you the option of stretch or shrink to paper size. Also, see if it says Crop Automatically versus copying or scanning entire glass. If there is a choice between Automatic, Home Mode, or Professional Mode, try each one. There is always a reset button to return to original defaults. If you are given the option of seeing a preview first, always do that, even though it takes a little longer.
Aug 06, 2008 | Dell A960 All-In-One InkJet Printer
Copy size
Please let me know If you make a scan. The Output its same as in the hard copy or Shrinked. If its shrink then its problem from scanner. Needs a setup. Else Refer back to me.
Mar 13, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Shirnking
Most all copiers have a built-in expansion factor of about 1% to account for slop in the paper feeding. The only way to change this is to go into the lens area and move the lens so that is closer to the drum, however this might open a whole new set a problems, with borders appearing at the edges of your copies. CAUTION: It takes only a small amount of adjustment of the lens to make a noticable difference in the size of the copies. Hope that this helps. Aloha
Aug 29, 2007 | Canon imageRUNNER 3570 Copier
Ricoh Aficio 2015 Copier Logo
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
