Question about Maytag Bravos MTW6600T Top Load Washer
Cannot spin maytags bavos drum by hand - Maytag Bravos MTW6600T Top Load Washer
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Gear box gone
Posted on Jan 18, 2013
4 Suggested Answers
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
SOURCE: maytag washer spin trouble drums moves from side to side
under the drum is a plastic support that can wear out. it must be replaced. if you do it yourself not too expensive
Posted on Apr 20, 2009
  • 64 Answers
SOURCE: maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Posted on Jun 10, 2009
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
Motor smell hot drum will not spin or pump out water Maytag atlantis
Im not an expert, but.Ok, but it wash? The only problem is at spin? if not wash at all:
Disconnect from the outlet, remove the belt, and by hand turn the pump and drum. Its suppose to move with low resistance in both directions, will not spin freely, but turn easy by hand. Do the same with motor. IF the drum and pump moves in both directions, I suspect about the motor.
If the only problem is at spin:
Do the same, but place special attention at the drum when you turn in reverse. Look if you see the brake Disk turn.
Nov 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
Maytag washer, buring rubber smell, drum won't turn
the drum should run free if not the bearing have gone and seized they will need to be replaced. hear is a video there are others you can find the bearing kit on line using the model number https://youtu.be/WGolkFlgl3Y
Jun 22, 2017 | Maytag Washing Machines
Grinding Noise
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Hope this helps.
God Bless.
Jul 08, 2009 | Maytag MED9700S Electric Dryer
Maytag washer spin trouble drums moves from side to side
Apr 20, 2009 | Maytag Washing Machines
Maytag performa pye/g2200,3200
when you say the drum wont spin even manually. Do you mean the drum is too stiff to turn by hand? If so the bearings may have seized up solid. If the drum is free to turn by hand, the pump may be blocked, or burned out & not allowing the water out. If so the circiut wont allow the machine to spin. If thats the case, unblock or replace the pump
Oct 20, 2007 | Maytag PAV2300 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
