Motherbord problem - Computers & Internet
  • Dick
    Dick May 11, 2010
    It's the 250 picovolt capacitor, just to the left of the 250v light brown ceramic resistor. Let me know if you need more help.
I have problem with my mother board as my orignal processr was intel 933 mhz i have changed the processor with intel 366 mhz and after that i re instlled my orignal processor 933 mhz but system does not boot on my orignal processr
Posted on Jan 26, 2009
  • anwar_jamil4 Jan 26, 2009
    i have problem with my mother board as my orignal processr was intel
    933 Mhz i have changed the processor with intel 366 Mhz and after that
    i re installed my orignal processor 933 Mhz but system does not boot on
Dosen't boot
Open cpu cabinet.
Refix RAM memory.
Clean dust from all parts.
Reattch ATX power connector from smps to motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings are defaults.
REmove pci cards from pci slot of motherbord then check.
Open processor fan and processor then refix both.
Make sure motherbord not ground with cabinet cover.
Then check if still problems then change ram .check RAM and motherbord separately .
Nov 21, 2009 | HP Computers & Internet
When I turn on the computer I can't see anything. I take off the RAM and turn on the cpu and does not happend anything. What should I do next ?
eset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Let me know if you need further assistance.
Nov 16, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I have install a new mother board, but when i power the computer the power come on, but no response on the monitor
Or reset motherbord settings to defaults you can reset with 2 methods.
Nov 15, 2009 | Asrock K7S41GX SiS741GX Mainboard...
Ge pro-ht it beeps three times long
Nov 11, 2009 | Asrock GE Pro-HT R3 Socket 478 Motherboard...
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
My board will power up but i cant get any video dont know where to srt jumpers
Nov 10, 2009 | PC Chips P23G Motherboard
Intel d845gvsr motherboard p4 processesor if computer is on then no display . so i see , don;t heat processor.
First open cpu cabinet.
Refix RAM memory on motherbord.
Remove PCI cards from motherbord.
Pull CMOS cell from motherbord for 15 minutes so all settings defaults.
Make sure your motherbord not ground with cabinet.
Then check.
If processor and circuit are heat high then put extra fan in cabinet.
Thanks.
Nov 03, 2009 | ASUS P5V800-MX Motherboard
My computer will not boot. The power will come on and the cooling fans will just continue running.
Open cpu cabinet.
Refix ram memory.
Pull cmos cell from motherbord 10 minutes then refix it.
Remove pci cards from motherbord if any .
Open processor fan and processor refix both.
Make sure motherbord is not ground with cabinet.
Check motherbord in outside of cabinet.
Reconnect all connection to harddisk.
Let me know if you need more assistance.
Thanks.
Oct 31, 2009 | Gateway GT5220 PC Desktop
Emachine T2742 wouldnt start, new powersuplly installed green board light on but still no response. switched out ramstick,stiil nothing. switched out main processer still no.hard drive OEM is ok what...
First Pull cmos cell from motherbord for 10 minutes because sometimes low voltage of cmos cell creates this problem .
After remove cmos cell from motherbord for sometime your bios settings goes to defaults.
Then check.
Also check that smps is work fine .
It is square box on back side of cpu .
Also make sure that motherbord surface not touch the cabinet.Check motherbord in outside of cpu .
Let me know if you need more assistanse.
Thanks.
Sep 14, 2009 | E-Machines eMachines Desktop PC
On and off button will not work. Is this easy to
open cpu cabinet .
check on motherbord corner side cable pin from power on/off switch to motherbord corner pin jumper correctly.
check on motherbord you find power on/off PIN jumper you cna ground it with any metal like screw driver. then if power on then you have to check that cable or still not start then you have to reset factory defaults settings of motherbord.
For thta pull cmos cell from motherbord for 10 minutes .
Then check.
Aug 21, 2009 | Computers & Internet
Computers & Internet Logo
365 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
