Question about IOGear 4 Port Hi-Speed USB 2.0 Hub
Iogear 4 port USB 2.0 HUB (Model GUH285) now working properly
Ok. So when i first got my hub, it worked fine and i was able to use it for all my USB needs. But for some reason it stopped working one day. Such as, it won't recognize anything i plug into it. Some things such as a flash drive will light up and then disappear, and it will not be shown on my computer. And my external HD when connected, its LED light will turn on showing its connected and on, however it will not show up anywhere on my computer. I don't think the hub is fried because it still almost recognizes stuff being plugged in. Even my ipod turns on when a USB cable is connected to it, although it will not do anything.
  • swaudby Feb 28, 2009
    Brand New, from MacMall.  I tried using it on my brand new MacBook Pro and also on my Toshiba running Vista Premium.  It doesn't work on either.  I got it from MacMall free after a rebate, but I would recommend anyone against purchasing this item.  There is no support on IOGEAR's website.
    Problem Solver:
  • 10 Answers
I think it clearly states that the device is defective.... you need to call IOGEAR for RMA if its still under warranty
Posted on Feb 02, 2009
How in the Hell is one supposed to understand the instructions for the IOGear GCS932UB. I cannot get the unit to detect my powered usb hub. No information is displayed when you try any function so I never...
If you trying to use the USB hub through the mouse port of the KVM make sure the mouse emulation has been turned off. This can be done by tapping Scroll Lock + Scroll Lock + m + Enter. This turns the mouse emulation off and causes that port to act like a direct USB connection to the computer. Instructions for this can be found in the user manual on page 14.
http://www.iogear.com/support/manual/GCS932UB_Manual.pdf
Apr 24, 2010 | IOGear Computers & Internet
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
Acer 5720G has lost power at USB ports
it shows the hub issue, if hub is ok (try it to other system) then the acer did not support such hub to power up.
Sep 16, 2009 | Computers & Internet
I have a Q-Stor 7 port USB hub, Model QU2RCT7. I
I don't have the original power supply for my QU2RCT7 either, but most hubs use a 5v DC power adapter, typically with a 2A. (2 amp) rating. I'm using such an adapter with my QU2RCT7 and it works fine. Make sure the adapter you select is tip-positive (ie, the "+" terminal is the "tip," or center, of the connector).
Sep 14, 2009 | QPS (QU2RCT7) 7-Port USB Hub
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
DELL STARTUP
There was problem at one time with IOGear KVMs not working correctly with the USB chipset on the Dell motherboards. This problem was resolved by using a USB hub between the KVM cable and the computer. The user could take the USB portion of the KVM cable and plug it into a USB hub and then take the USB hub and plug it into the Dell computer. That should help with the problem.
Oct 16, 2007 | IOGear GCS632U 2-port KVM Switch
IOGear 4 Port Hi-Speed USB 2.0 Hub Logo
590 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
