Question about Toshiba Satellite L875D-S7230 Laptop
Loss of Wi-Fi connection
Loses connection with wireless router, and shows an unsual, random IP-address AND MAC-address when viewing the "details" of the WLAN-network connection. Was working for a short time prior ( even accesses the internet ) but just suddenly loses its wireless connection. If it does connect to the WiFi, Windows7 says it is an "unidentified network" when its connect-profile states it is connected to our home SSID. Tried a USB WLAN adapter with its own driver CD, and ended up with the infamous Windows B.S.O.D., but manages to reboot on its own. We did save a text copy of the system error msg to a text file. This computer has had a replacement hardrive within its first 45-day use due to the original harddrive crashing and becoming unrecoverable. Laptop worked fine for a while, but now these networking issues. This machine is barely six months old and is giving us these problems already. Any ideas (I am thinking it is a hardware problem - being that I am aware that there were some problems with some earlier models).
mspcrepair
  • 169 Answers
SOURCE: Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
pontelemon
  • 531 Answers
SOURCE: no network connectivity, missing drivers
Enable DHCP on the router.
And try this driver:
http://cdgenp01.csd.toshiba.com/content/support/downloads/s240ethx.exe
Posted on Apr 14, 2009
Wiired
  • 122 Answers
SOURCE: Problem connecting to router
Log into the Belkin router and make sure that the DHCP services are running. If it is, and you still are not getting addresses, perform a factory reset of the router. There is a link in the web management console to do this.
Posted on Jun 22, 2009
Geekman
  • 32281 Answers
SOURCE: My new Toshiba Satellite L300-20W will not connect
This problem is common.
This error message occures when the wireless card does not get an IP address from the wireless router. To get the wireless router to issue the wireless with a new IP address the connection needs to be repaired.
Right click on the wireless icon and click on repair.
Posted on Jul 30, 2009
Dumaine
  • 112 Answers
SOURCE: Hi, I was on Internet, suddenly
shut everything down..........restart the modem first.......wait bout 2 minutes, then restart the router, wait.......then restart the laptop
Posted on Aug 06, 2011
My connection keep failing my password is correct.they are asking for my ip address where do i find that,
dont give anyone your ip adress,contact your internet provider to fix problem,if you are using someone elses wifi you will have that problem,use your own
Apr 26, 2015 | Amazon Fire TV Stick
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Were do i find ip address
Assuming that you mean the router's ip address, I have to suggest this simple trick. Connect your computer at the router and after the connection has been established, hit start - run - type cmd. At the new black window type ipconfig and hit enter. You will get the results for both ethernet and wireless connections if any wireless is available). The line for "Default Gateway" is the ip address for your router. Use this address in your browser to log in at the router to make any adjustments (using the credentials for the router - username, password)
HINT In case you use a laptop with wi-fi connection and you're about to make changes on the wi-fi, use an ethernet cable to connect the router with the laptop in order to avoid locked you out of your wi-fi in case of an error.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 03, 2011 | D-Link DIR-615 Wireless Router
Samsung Galaxy GT-I9000 keeps trying to obtain ip address from home wifi but does not connect, but at work it connects to work wifi with no problems. Work is using a WEP encryption but my home is using WPA...
  • Go into settings
  • Wireless and settings
  • Wi-Fi settings
  • Click on the menu botton and select advanced
  • Select use static IP
  • IP address would be a random IP address from your wireless router
  • Gateway would be the gateway address from your wireless router
  • The netmask is your subnet mask address
  • The 2 DNS addresses are your Default Ip address from your own router and wireless switch
  • If you have issues copy the details from the Ipconfig /all command from Dos
Nov 25, 2010 | Samsung Galaxy S GTI9000 Smartphone
My iPhone does not connect to the Zoom X6 DSL modem. I can connect my laptop and a couple other wireless devices but not my iPhone. Is there a setting I should change either on the router or on my iPhone?...
there is 2 possibility 2 change in router first WEP or wpa security code if in your router need password for connect it then you need to find that key code to enter in iPhone.
Second if in router MAC filter is enable then you need to add your iPhone MAC address in allow list of router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
First find the mac address of your iPhone in network setup menu then add that mac id in mac filter of router configuration menu.Then save settings and check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 05, 2010 | Zoom X6 (5590) DSL Modem (55900003)
I have a laptop dell with vista windows, i want to make it wireless , using my wireless router ,how do it using the model of birght house step bystep. thank you.
You need to configure your router.
http://192.168.0.1
or
http://192.168.1.1
Enable DHCP if you want to get ip from router.
Then in vista make sure wireless lan driver installed then right clickc on wi fi icon and click on view available wi fi then you can connect it.
May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
I HAVE AN OLDER TRUEMOBIL 2300 WIRELESS ROUTER WERE ARE THE KEY CODES TO MAKE IT SECURE OR DO I ENTER MY OWN AT RANDOM?
You can secure your wireless network wit WEP or WAP code.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Dec 22, 2009 | Dell TrueMobile 2300 Wireless Broadband...
How do i protect my unsecured home wi-fi network? I have a Belkin router IP address 192.168.2.1.
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 19, 2009 | Belkin (F5D7230-4) Router (587009)
Toshiba Satellite L875D-S7230 Laptop Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
