LG 42L55 intemittent loss of sound
We have an LG 42L55 Smart TV bought in July 2012. From time to time we loose sound- it's not a total loss of sound. If we turn the sound to MAX we can just hear it. Repeatedly turning the TV off /on clears the problem. Any idea what the cause is?
SOURCE: lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Posted on Mar 20, 2008
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
SOURCE: 2004 GMC Envoy XL Loss of power
I also have an '04 Envoy XL. The problem we had was very similar. The truck lost power and the wife and kids were stuck on the interstate. It was the catalytic converter totally clogged. We were told by our trusted mechanic that we were lucky not to have blown a head gasket from the back pressure. Two days after having the converter replaced the check engine light came on. I went to Autozone to have the codes read. I don't remember the code number but it was basically that the thermostat was stuck open and the engine was running too cool causing it to run rich and clog the converter. I did not get a light until after and the light went out on it's own. I hope this helps you. GOOD LUCK!
Posted on Jul 07, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 42 Answers
SOURCE: LG rear projection tv. sound but no picture.
Go to a repair centre, some parts must be fixed/replaced.
Posted on Jul 22, 2009
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
My odometer and information panel on my 98 century 120 is in Spanish how do I change it to English?
Questions, Troubleshooting Help & Support - Fixya
www.fixya.com/troubleshoot
How do I remove and reinstall a TPS on a 2000 Toyota Camry ... My odometer and information panel on my 98 century 120 is in Spanish how do I change it to English? ... Hi i have panasonic 55 inch smart tv bought in 2012 ..sound is coming but no picture..i can change channels and ... TD-3018 User Guide English.pdf.
Dec 20, 2015 | Computers & Internet
Pluged in smart cycle in t.v. and smart cycle will not come on please help
I had a similar issue. My Smart Cycle worked for a while, then it progressively became more and more temperamental, failing at unusual times, not turning on consistently, then finally quit powering on entirely. Turns out there was dirt & grime (maybe a little corrosion) on the game cartridge and plug. The solution -- clean with Windex and q-tips.
Here's the post that led me to that conclusion:
http://www.fixya.com/support/t317354-smart_cycle_fisher_price
And more on cleaning the cartridges and console plugs in general:
http://blog.pricecharting.com/2012/03/how-to-clean-video-games-consoles-with.html
Mar 30, 2011 | Fisher Price Fisher-Price Fisher Smart...
KV35S42
Classic bad picture tube! End of natural life for that make/Model.
The  current sensing circuit is turning the video on/off.
The orangey look also indicates CRT no good.......T.
Oct 20, 2007 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
