Sony 2197M3 Horizontal blue lines in screen
There are some horizontal parallel blue lines in my TV. It is not so much obvious but They are there on my screen.
SOURCE: Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Posted on Oct 09, 2007
CrazyLarry
  • 173 Answers
SOURCE: Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Posted on Jan 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
Posted on May 23, 2008
  • 133 Answers
SOURCE: Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Posted on Jan 08, 2009
SOURCE: Akai PT 5299 HD Rear Projection TV
That sounds like a high-voltage splitter, failure!
Posted on Apr 03, 2009
Blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Nov 14, 2009 | Televison & Video
Transistor d1878 get over heat
i have a sony kv-2197m3 i replaced tr D1878 tv turn on,but image it's bad in horizontal seize and tr D1878 was shorted again what's the matter? chek68@gmx.fr Post Solution
Oct 11, 2009 | RCA 27F530T 27" TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
HORIZONTAL BLUE LINES
you will probably need a blue picture tube
Jan 11, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
