My LG WD-8015C front load washing machine fills with water but then nothing happens. it doesnt matter which cycle wash, spin etc does the same thing all the time. Have cleared the outlet and that is working fine. the only cycle that works is PUMP which gets rid of the wayter ok. The drum motor is not even trying to start and its completely free under hand rotation ie not seized or anything. Any suggestions welcome
  • brett c Jul 09, 2013
    mine has exact same symptoms but it is not the belt, the motor does not start
    Problem Solver:
  • 10 Answers
Heater element? Brake motor? Dont exist on this machine! Obviously some people commenting are not familiar with this machine, I am not stirring but rather correcting misinformation which people just find confusing.
I have the same issue with my machine and do not have the answer but I know there is no heater element or brake motor on this machine, my brushes are in great condition, its a belt drive and belt is not broken, motor is fine.
I can hear a relay click when it tries to rotate the drum but nothing happens, I inspected the control panel and found a relay that looks like it got very hot and melted to a resistor thingy next to it. I believe this is the cause of the problem but a new control panel will cost around $200, more than the machine is worth, hope this helps.
P.S. I bought a new machine.
Posted on Aug 07, 2013
Sounds lke the belt has broken
Posted on Jan 18, 2013
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 1462 Answers
SOURCE: Creda Excel 1200 W120VW Front loading washing machine
check motor brushes for a start
Posted on Jul 04, 2008
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
SOURCE: simpson enduro 701 washing machine
you have a faulty brake motor. It pulls in and releases the brake. When pulled right it it contacts a switch which lets the other actions like washing and spinning to occur. $77 to $86 off ebay or appliance stores. turn off ac. remove back off machine. reach around left side of frame at the bottom of the tub and push the brake forward manually and let the little plastic retainer turn sideways and release the wire rope retainer that comes out of the brake motor. remove the power cable to the brake motor by pulling out the connector on the right side under the tub. remove the two 8mm screws retaining the brake motor and remove the brake motor. reverse procedure with new item.
enjoy uninterrupted washes!
Posted on Jun 21, 2010
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
LG 7kg wd 8015c
possibly the lid switch when you put the lid down is bad
Nov 09, 2013 | Washing Machines
LG Intellowasher 7kg wd-8015c leak
Most of the time it is the door seal, open the door and check all the way round. check the sump hose and pump, sometimes it can leak from the soap draw hose to the outer tub, but not in your case I think. In most cases this can be fixed easy and is the door seal. to find out if it is coming from the front or the back, just place some news paper on the floor under the machine and take a look to see if it is the front or the back. a door seal is about 15/25 pounds retail
Oct 24, 2012 | Washing Machines
Instruction manual for LG WD 8015C
This link (below) to LG website will get you there, once loaded, click "Support" on the right hand side tab, then on the right side again, you will see "documents" this will get your manual etc, you will however, need to install Adobe Reader if you don't have it already, this is fairly straight forward though. I hope this helps.
http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-front-loader-washing-machine-WD-8015C.jsp
Jun 19, 2012 | LG Washing Machines
The water is on but the water doesnt fill the washer. the spin cycle works how do i get the water to fill the washer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | Maytag MAV8557 Top Load Washer
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
