Question about Cameras
Format memory stick - Cameras
    Genius:
  • Cameras Master
  • 1,019 Answers
Press menu, setup and scroll down to format.
Posted on Jan 26, 2013
My 4gb memory stick pro duo didnt work on sony vaio vpcw21eag card reader magicgate hg duo.. pls help me... my operation system win 7 ultimate.. help me...
if your 4gb memory stick are not working,i suggest format your 4gb memory stick and use. step for format it , Right click on my computer and click on manage after open manage window click on Disk management tab after few second your 4gb memory stick are display it, right click on 4gb memory stick and format, select quick format , ok after few second complete format message are display , click ok and use your 4gb memory stick.
Jun 22, 2011 | Computers & Internet
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
Format a memory stick?
connect the memory stick to the computer. open (my computer) you will find an icon for the stick, right click on the icon then choose format.. a windows will appear, then you can format it normally.
Oct 02, 2008 | SanDisk 4GB Memory Stick Micro M2 Memory...
Format error
i have orignal memory stick but i am also getting same error.. have forated stick on camera but no effect on error. so plz can u tell me how can i format my memory stick ... SONY GURU
Jun 07, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cameras Logo
12 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
