Question about LG WM-2277HW Front Load Washer
Front load washing machine - LG WM-2277HW Front Load Washer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
So wat ,and its doing wat
Posted on Jan 18, 2013
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
My frigidaire front load washer Model #GLTF2940E will not spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washing machine is washing but not draining or spinning
heatman101
Apr 26, 2011 | Indesit W 123 Front Load Washer
Frigidaire front load wash machine isn't spinning.
heatman101
Apr 17, 2011 | Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Have a whirlpool front load duet. Will not rinse or spin
    Problems with a washing machine not spinning or not draining are often inter related..
    If you are having a problem with your top load washer then check out this tip...
    If you are having problems with your front load washing machine then checkout this tip...
    heatman101
    Sep 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Frigidaire front load washing machine won't drain
    heatman101
    Aug 31, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
    Which washing machine is better front load or top load?
    Front load washing machines are better than top load money wise.
    One advantage of a front loading washing machine is an increased capacity. Since there is no central agitator, the horizontally-oriented drum can hold at least 20 to 30% more clothing per load. For a large family, this could mean running only three loads in a front loading washing machine compared to five in a top loader. Fewer loads often translates to savings in utility bills and water usage.
    Another advantage of a front loading washing machine is less water and detergent usage. A top loading washer must use enough water to cover the highest level of the clothes. A front loading washing machine, on the other hand, only uses enough water to cover approximately the lower third of the tub at most.
    Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
    When washing a load the machine is not spinning.
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
    My GE WBVH6240FWW front load washing machine won't spin.
    heatman101
    Jul 01, 2009 | GE WBVH6240F Front Load Washer
    LG WM-2277HW Front Load Washer Logo
    16 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
