Question about Compaq Evo N610C Notebook
Black screen on compaq presario v5000
My computer has a black screen it shows the battery light and if it is charging but that is all. apon turning it on the fan starts but sounds really bad choppy, then stops and if there is a cd in the optical drive it will try to read it. but the screen stays black and there is no beeps or anything.
  • wnina3 Jan 25, 2009
    i tried to connect to external monitor and nothing appears on that screen either. tried to reboot in safe mode and i get nothing. the hard drive light that usually appears when u turn the computer on does not appear. i tried disconnecting the screen and then reconnecting but that did nothing, i also tried to take battery off and ac adapter, hold the start button down for 60 secs and then plug adapter back in, that did nothing either. I'm totally at a lose.
    thank you for your help!!!!
    Novelist:
  • 126 Answers
The very first thing that u can try is that try it with the different ac adaptor and the battery and try it with the differnt ac aaaadaptor and still it doesnt then wahat u said is that u can hear the sound of the fan and the disk is trying to read but u cannnot see anything on the screen adn all u need to clearify is that if the computer is actually running or not and if it is working then what u can do is that connect the external monitor and then try and turn on the laptop and if u get a good display in te external monitor then definately replace the lcd screen and also what u can try is that try and reboot the computer in the safe mode and if turns on and u can see the display in the screen then do the system restore and it will be fine.......and as u said that u get a choppy sound from the fan then what u can do is that try and clean the fan from the back or by opening it......anbd it will not get any sound from the fan......good luck....
Posted on Jan 25, 2009
  • ramesh singh
    ramesh singh Jan 25, 2009
    ok in that case wwhat u can do is that simply relace the system motherboard and the ac adaptor and then it will definately work......take care
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
http://www.chargerbuy.com/replacement-compaq-presario-v5000-ac-adapter-65w-18-5v-3-5a.html
Nov 20, 2012 | Compaq Computers & Internet
Presario V5000 - Thee machine was borrowed out
look it may be a static charge on the motherboard but there are alot of things that make this kind of problems to cut them out try to plug the notbook on external monitor and if it worked you will have a problem with your screen if not then there is a problem in the motherboard
Nov 08, 2009 | HP Compaq Presario V5000Z Notebook
My screen stays black when you turn it on. model HSTNN-C17C which is located under the battery. Presario V5000
This isn't a desktop PC by the way. Do any of the lights come on? If not, try to run the laptop from the AC power. If the lights come on but no display, then your backlight or inverter on the LCD panel for your V5000 might be bad.
Oct 08, 2009 | Compaq Presario 5000 PC Desktop
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
COmpaq Presario V5000 Battery will not hold charge
Problem with the motherboard connector that charge the battery.
Oct 03, 2008 | HP Compaq Presario V5000Z Notebook
Needing to fix a compaq presario v5000
The screens on these computers can and will go dead after a while, afterall its an old computer..try an external desktop monitor by plugging it in the back(blue port)
If you want a new screen go here
Good luck..and if you have any questions about your armada just ask.. I have 5 of them.
Oct 01, 2008 | Compaq (241995001) Plug-In Module (Laptop)...
Blank screen problem witn presario v5000
This will not kill your computer don't worry.
What would be mt suggestion for you, please get your presario v5000 reimage with all the drivers.
Thanks
Aug 25, 2008 | HP Compaq Presario V5000Z Notebook
Compaq v5000 wont turn on
Shorted MOSFET in the secondary most likely.. These are trash..
Nov 14, 2007 | Compaq Presario V5120NR Notebook
Compaq Evo N610C Notebook Logo
1,087 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
