Question about Princeton Digital VL Computers & Internet
Server #5 is under the DDOS attack (IP Nullrouted) We have just received a HUGE (over 3GB/s incoming traffic) DDoS attack targeting the Server #5. Our CISCO guard firewall was unable to handle such attack, so one of the server IP address - 31.170.164.143 was disabled (all the rest websites on this server are working fine). If your website is using this IP (due to unique IP rotation system only 3% websites are using this IP) it will be unavailable for the next 6 hours. As soon attack will subside, this IP address will be enabled and your website will start working again. We thank you for your patience and understanding. 2013-01-18 01:07:54
  • 59 Answers
SOURCE: linksys print server psus4 held
I've worked with literally hundreds of these exact print servers. The answer is really not much of an answer. The device requires a restart often because it locks up. After hours and hours with Linksys and a few custom firmware tweaks...still locks. Sometimes we just have to accept that things don't always work the way they are supposed too = "junk". Although I will tell you this, of all the print servers we have tried, this one is NOT the worst. Incidentally, there is no sleep option on that model print server. ...for what it's worth.
Posted on Aug 25, 2007
SOURCE: Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Posted on Jun 10, 2008
voodoomox
  • 1689 Answers
SOURCE: useing Linksys wpsm54g with tcp/ip
that will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
Posted on Oct 01, 2008
  • 37 Answers
SOURCE: My website on my network open the netopia router page
You need to somehow setup the internal DNS to route all requests for the specific domain name, to your internal website.
Or, setup the netopia to allow loopback connections.
If you have a 2003 Server OS, chances are that the server is handling DNS requests, at least internally.
This tutorial has a good example of how to create domains internally:
http://www.simongibson.com/intranet/dns2003/
Just a couple of tidbits when using this approach:
You will essentially be controlling the DNS for the domain internally anyways. Meaning, any subdomains, mail exchangers etc., for the domain will have to be configured as well.
Good Luck.
Posted on Mar 10, 2009
SOURCE: Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Posted on Mar 12, 2009
Have they found a definite solution? cause it is happening and i dont know what to do to fix it
PlayStation network experienced an attack by hackers today, attempting a DDOS attack. If other attempts to fix the tour pool error on your end has failed it likely is a problem with the server you are attempting to connect to.
Dec 25, 2014 | Sony Playstation 3 (PS3) Console
How to setup and web server and update its frontpage site
for creating a web server you will have to buy.
a public ip address and aserver machine with windows server os Like IIS server.
it will be too costly
Aug 03, 2009 | Microsoft FrontPage 2003
Web page will not load
are you loading website trough internet or hosted locally with local web server. give me more detail i will able to fix it for you.
Dec 11, 2007 | Computers & Internet
How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described in How is Port Forwarding Configured? However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RO318 Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 (MR314NA) Wireless Router
How To Make a DMZ
Feb 19, 2006 | NetGear MR314 802.11b
How To Make a DMZ?
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants ? by throwing all ports open for that computer. For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding. However, the DMZ server feature is helpful: * When you have a problem connecting to an Internet service. Setting up a DMZ will determine whether a closed port is responsible for the problem. * With some online games and videoconferencing applications that are incompatible with NAT. Follow the procedure under your router model to create a DMZ To Create a DMZ for RP614, MR814, FVS318, FVM318, WGR614 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the username and password for the router (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. Some routers, such as the MR814, use the WAN Setup Options, page, instead. 4. Enter the server's IP address. 5. Click Apply. To Create a DMZ for FR114P, FR114W, FM114P, FR328S, FVL328 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username is admin and password is password). 3. From the browser Main Menu select Advanced > Security. 4. Click Rules. 5. Check the box for Default DMZ Server, and enter the server's IP address the corresponding box for the IP Address. 6. Click Apply. To Create a DMZ for RH340, RH348, RT328, RT338, RT311, RT314, RP114, RO318, MR314, DG814 * Going through the GUI and going to Port Forward in the left menu bar. * For RM356: Going through telnet and from the main menu go to menu #15. 1. Open a Web browser, and type the router's IP address (The router's default IP address is 192.168.0.1). Click Go. 2. Enter the router's username and password (Default username admin, password 1234). 3. From the Main Menu of the browser interface, under Advanced, click Port Forwarding to view the port forwarding menu. 4. Enter the IP address of the DMZ server in the corresponding Server IP Address box. 5. Click Apply at the bottom of the menu.
Feb 19, 2006 | NetGear RP114 Router
Computers & Internet Logo
93 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
