Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
How to replace cartridge on blanco single handle
  • sjott Jan 30, 2009
    I have the Blanco Master Gourmet faucet.  What tool do I need to remove the handle so I can access the cartridge which is leaking?  allen wrench, flat or phillipshead...?
  • 4 Answers
Somewhere around where the handle fixes to the tap should be a grubscrew of some kind undoing this will allow the handle to be removed this will give you access to the cartridge which can then be removed with the correct socket, obviously you will need to turn off the water supply to the tap first!!
Posted on Jan 27, 2009
As noted previously, make sure the water is turned off before starting. Pop off the small blue and red plastic disk that indicates which side is hot and which side is cold. Underneath that is an allen screw that will release the handle from the cartridge control stem. Then unscrew the ring holding the cartridge in place.
Posted on Apr 11, 2009
4 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: i have a single handle blanco classic that is
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Posted on Nov 07, 2010
  • 1751 Answers
SOURCE: I have a Blanco Single Handle faucet with Pull-out
you need to open the mechanism and clean it
there is dirty in and must be clean
Posted on Jan 14, 2011
packrat1948
  • 528 Answers
SOURCE: I have a Blanco 157-081-ST Single handle, satin
If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
Posted on Feb 12, 2011
Cartridge replacement
Should be able to order new one at any plumbing supply. Remove handle, then with pliers pull out old cartridge, and push in new one till it seats, place handle back on.
Oct 25, 2013 | Blanco 157-013-CR Harvest Kitchen Faucet...
Leaking blanco single handle faucet with sprayer
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
Mar 11, 2012 | Blanco Plumbing
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
How do we repair leaking faucets and clogged drain
Hi. To fix leak, replace cartridge in valve. To clean out drain, Clean out trap under sink.
Jun 09, 2011 | Blanco Classic Single Handle Faucet with...
I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
The tap is leaking it appears at the bottom of the tap where it meet the sink it is a hansa single handle with vegatable sprayer with a ceramic cartridge
Hi, there are flexible water pipes that scew into the bottom of the tap, one of these could of come loose; try tightening, or the washer may need replacing.
Hope this helps
Jul 21, 2010 | Blanco Classic Single Handle Faucet with...
Just installed a new Blanco Torino, model 157183, and inadvertantly got saw dust in the waterline during installation. It is restricting the pressure on the faucet. What is best way to clean it out?
I would try to unscrew the spray head from the hose and turn the water on to see if you get good flow from the hose. If so you need to clean the head, if not you will have to start taking the faucet apart and cleaning or possibly replacing the cartridge
Jun 26, 2010 | Blanco Classic Single Handle Faucet with...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
1,930 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
