Question about Panasonic TH-42PX500U 42 in. Plasma Television
After following the reset procedure the set is unresponsive
I followed the reset procedure on page 34 of the owners manual. At some point in the process the video went snowy and the on/off switch is the only thing that works on the TV.
I have tried turning off and on as well as unplugging the unit. At this point the TV is useless.
  • 2 more comments
  • mikec905 Jan 25, 2009
    I tried unplugging the unit for 15-20 minutes. No change.
    I don't believe that the channel was changed.
    I now have a signal from the satellite receiver, however, none of the controls work, i.e. volume control, menu, channel, video input, etc do not work.
    Satellite receiver is connected thru antenna/cable connection.
  • mikec905 Jan 26, 2009
    Unresponsive using either the remote or the TV controls.
    One of th experts asked if the picture was snowy when connected to DVD. The problem is that I have no control over the inputs and cannot select anything. Therefore I cannot provide an answer to this question.
  • Panasonic Master
  • 19,396 Answers
Unit being not responsive has got nothing to do with the no signal problem.
You have an additional problem with the remote, try replacing remote batteries with new ones.
If you are using a programmable remote, remote may need re-programming after TV reset.
Posted on Jan 26, 2009
  • 11,896 Answers
After hearing your problems and solutions and researching and talking to tv techs for 2 days, I believe you need a new main digital board
    Genius:
  • 1,199 Answers
Push and hold power button for ten seconds!
  • 3,037 Answers
You may have gone into factory or service mode. See if the manual says anything about either one, You may have to hold down a certain button for a while like the menu button to unlock it and get into a special menu.
bestdarngood
Posted on Jan 25, 2009
    Sergeant:
    Champion:
  • 435 Answers
Are you trying to control using remote or on the TV set?
If its the remote, their might be problem with the remote or the remote-TV communication.
If the picture is snowy, is it snowy with any DVD/ Video CD you play?
  • 565 Answers
Sounds like u need to rescan the channels
    Brigadier General:
  • 8,619 Answers
Hi
You can try the link on which you will find everything -
http://www.devicemanuals.com/guide/Television/Panasonic/Panasonic-TH42PX500U-42-HD-PLASMA-TV-TkRVd09RPT.html
Thanks
Rylee
  • 10,515 Answers
Heat is the enemy of electronics, and these sets operate hot. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solderconnections.This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
thnx.
    Brigadier General:
  • 5,158 Answers
A couple things... have you unplugged it for about 15 minutes or so... and did you inadvertedly change the channel from 3 or 4 ?
Robert
  • Roberta Smith
    Roberta Smith Jan 26, 2009
    take the batteries out of the remote for a few minutes and see it that resets it and gives you control.
How do I change my Lincoln towncar 2001 from km to mpg ?
page 6 of your owners manual shows how to set and reset your instrument panel the following link is the owners manual for 01 town car
2001 Lincoln Town Car Owner Guide 4th Printing
Aug 24, 2016 | Lincoln Cars & Trucks
Loading issues please help xx
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Jan 05, 2015 | Android Gemini Tab
How to set radio clock in 2013 Dodge RAM
follow this link to download a owners manual for your vehicle , page 300 give the radio clock setting procedure
My Ram Trucks Ram Owners Service Manuals Ram Cars Minivans SUVs
Sep 27, 2014 | Cars & Trucks
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
ETrex Venture HC Car GPS Receiver: How do reset unit back to factory spec's...
Hi!
From your owner's manual, to reset to factory defaults (Page 34)
http://www8.garmin.com/manuals/eTrexVenture_OwnersManual.pdf
Select the route page options button and press the Thumb Stick in to access the options menu.
Select "Restore Defaults" and then press in on the Thumb Stick to restore factory settings.
Hope this is of some help to you.
Good Luck!
May 07, 2010 | Garmin eTrex Venture HC GPS Receiver
Oil change signal still on after oil changed
To reset the oil monitoring system to 100% after each oil change
[approximately 8 000 km (5 000 miles) or 180 days] perform the
following:
1. Press the SETUP control to
access the System Check function
2. Press and release the RESET
control to display “OIL LIFE XX%
HOLD RESET NEW”.
3. Press and hold the RESET
control for 2 seconds to display “IF
NEW OIL HOLD RESET”.
4. Press and hold the RESET
control to display “OIL LIFE SET
TO 100%”. Your oil life is now reset.
This procedure is on pages 69-70 of your owners manual, this is copied and pasted from that manual
Feb 18, 2010 | 2003 Ford Windstar
I have a error code F-34-1 in konica 7055
Hello sir; You need to reset, the procedure as follow; power off the machine, hold down 2 & 5 while you power on machine,then chose 1 soft switch setting, then dip switch 3 bit 1, 2, 3, 4 set to 0. then turn power off and back on.
Sep 26, 2009 | Konica Minolta Office Equipment & Supplies
I just cannot reprogram this unit following the instruction manual..Help!
once you delete them i bielieve there gone radio shack does carry a book of frequiences you can program in depends on what you want listen to
May 27, 2009 | Radio Shack Pro-84 Handheld Scanner
My TV remains on standby after following the manual's instruction on turning on the TV. What is the Power Control Setting? And where do I adjust. It appears the TV isn't getting power or I don't know
hi friend,,,
Power Control Setting means nothing that whether the incoming voltage is whether above 240 wats or below it if you have multimeter check it,,,,'
thank u,,,,,,,,
it will be also any burnt resistors problem
May 03, 2009 | Televison & Video
Cycles through startup - won't turn on
It looks like it needs a software upgrade
Why dont you try visiting a service point, or even you can try doing it
to reset the phone
Reset the
phone
Reset the phone to the factory default
settings.
Menu
> Phone settings
> Reset settings
The user manual is available on the following pages
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-C520-_E
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Apr 17, 2009 | Cell Phones
Panasonic TH-42PX500U 42 in. Plasma Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
