Question about Espressione Cafe Chic 1377
I bought kenwood es416 espresso coffee machine and the water does not go to the filter coffee, this is the first time I am trying it.. the steam goes through properly but seems a bit weak
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
My filter doesn't let the water go , it is block
It happenned to me so many times. Other than using the supplied "pin" Try cleaning your filter with the steam, it should clear up the gunk. Run it with plain water a few times before adding coffee again.
I got fed up after a few mornings and bought a new basket for $10.
Jan 03, 2011 | Breville ESP8XL Espresso Machine
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Blocked Kenwood Cafe Retro ES547 espresso machine
you could try to run some vinegar through the machine and it may clear the tubes. you will need a few runs of water through after to clear the machine though.
Apr 21, 2010 | Espressione Retro 1385 Espresso Machine
No water through filter head, noisy pump and now vibrating too
It is possible that the valve in the head is blocked use the diagram below to help you out.
Sep 18, 2009 | Gaggia Classic Espresso Machine
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
The red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Apr 22, 2009 | Saeco Magic De Luxe Espresso Machine
No steam
There is descaling and then there is descaling.
We have written a good article on how to descale saeco coffee machines which you may find useful.
Try a really heavy descale - use the recommended dosage of descale powder or solution in 3/4 the recommended quantity of water.
Run some coffee through the coffee side of your machine, then the water/steam side of your machine and then allow to sit for a good five monutes before repeating.
Do this until the solution no longer comes out with a greenish tinge and then flush both sides with fresh water.
Make you use on filtered water or an in tank filter in your machine.
If this doesnt work it's off to your saeco service center.
Paul from Coffee Shrine for Saeco Coffee Machines
Aug 20, 2008 | Saeco Classico Espresso Machine
Steam from brew head, but no water
  1. If you take the coffee filter and head it in light, can you see a little hole in the middle? if not, try to clean it else you have to replace it.
  2. Can you brew out water without the filter holder in the machine? If not, loosen the screw in the middle on the machine where the filterholder shall be and take of the filter. Clean the filter and put it on the machine again.
Hope this help you
Jun 10, 2008 | Breville ESP8XL Espresso Machine
Espressione Cafe Chic 1377 Logo
75 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
