Slenderton belt not start, E002 error code on window?
I gust change batteries and pads.
SOURCE: Canon PC-850 E002 Error Code
I fixed it by putting it in service mode. (paperclip straightened to act as a pin pushing the reset button behind the front cover and simultaneously holding down lid release spring on the left with a pen). It reset itself and no more error code.
Posted on Jun 04, 2008
  • 47 Answers
SOURCE: error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Posted on Jun 10, 2008
  • 16 Answers
SOURCE: a canon np 7161 with an e002 error code. It is my
ok let me help u on fixing your problem.
mostly this error is in fusing unit and may be due to power disturbance.
first press * (star) then 2 & 8 together again *(star) if succesfully u presed 2&8 together and then *(star) the number 1 (one) will appear in the box [ 1 ] then press 4 then A (automatic exposure) then 412 and finally finnish by pressing the start button/print button the machine will go OFF turn it ON it is now ok. if not start again follow the sequency untill to the step of pressing the start button insted of it press A.
try your best, kibokoyao waiting for your vote.
Posted on May 14, 2009
  • 118 Answers
SOURCE: error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Posted on Jul 05, 2009
  • 59 Answers
SOURCE: code error E002
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
Posted on May 15, 2010
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
Code error E002 for Canon NP6030
thanks
May 13, 2010 | Office Equipment & Supplies
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Cannon MF8180c - E002
Go to this link. Type "error E002" in the search window and click Search. Select the System Error E002 link and you will see some things to try to resolve the problem. If it persists, you may need to have the unit serviced.
May 22, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
jasbo
jasbo
