Question about York Barbell Home Use Fold-Up Treadmill
Change fan belt
Can you show me how to change the drive belt
    Top Expert:
  • York Master
  • 12,223 Answers
See the video and fix it.God bless you
Posted on Jan 18, 2013
Repacement of belt that drives the second radiater fan on jetta cli 2l 1992. the 1st one is driven electrically.
huh ... jetta cooling fans show up as electric direct driven
number one or five .... 2.... drive belt layout
or diesel last picture
Nov 09, 2016 | Cars & Trucks
Car broke down due to fan belt and no tensioner bolt. Is the tensioner connected to the alternator
Yes the belt runs over the alternator, A/C etc. This page shows how it works, and the tensioner needs to keep tension on the belt to drive the pulleys including the alternator.
1994 Dodge Spirit Drive Belt Diagram Other Category Problem 1994
Sep 19, 2015 | 1991 Dodge Spirit
Hi I have a 307 xsi 2L 2002 I recently had timing belt/waterpump both changed and yesterday the fan belt but the car is now worse than before whining noise squeking when in idleing and driving accept in...
readjust the fan belt and check the condition of the pulleys The secondary air injector is showing a malfunction ---causes are ---wiring---AIR valve--- AIR sensor--- ECMI would be checking the wiring and connections as they may not have been replaced properly after the timing belt work. Replace with genuine units only as some after mark units are not compatible with the cpu.
May 27, 2013 | Cars & Trucks
Jetta 4 v5 2000 model feen belt changing
Copy the following link to your address bar and see if this video helps.
http://www.youtube.com/watch?v=OQ7lbkid5gA
Apr 03, 2013 | General Fan Belt, Long GCB10850
Loose fan belt
It can be worn out fan belt or the fan is got dried up and needs lubrication.Inspect fan belt.
Check the help link mentioned below:----
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Dec 09, 2012 | 2007 Chevrolet Kalos 1.2
I have a 1989 jeep wrangler it does not have a serpentine belt but rather 3 belts i need a diagram showing how those belts are suposed to be routed
Check with Autozone and discuss your problem. They know what they are talking about and have always come up with the right parts or belts for me. I used to be a mechanic in my youth and I never go anywhere else.........
Sep 01, 2012 | 1989 Jeep Wrangler
DO i NEED TO RE-MOVE THE FAN TO CHANGE THE DRIVE BELT ON A 2005 TRAIL BLAZER
THE 4.2 ENGINE YOU DONT HAVE TO REMOVE COOLING FAN TO GET THE DRIVE BELT OFF.THE 5.3 ENGINE YOU HAVE TO REMOVE THE AIR CLEANER OUTLET DUCT.YOU NEED A 3/8 INCH BREAKER BAR TO INSERT IN DRIVE BELT TENSIONER ARM.TURN BREAKER BAR CLOCKWISE TO RELIEVE BELT TENSION.
Jun 27, 2010 | 2005 Chevrolet TrailBlazer
Worn Drive Belt
no..the belt should go around the fan
Feb 19, 2010 | 1999 Toyota 4Runner
Changing the water pump on 2000 Jeep Grand Cherokee V6
WATER PUMP
The water pump is bolted directly to the engine timing chain case/cover.
A gasket is used as a seal between the water pump and timing chain case/cover.
If water pump is replaced because of bearing/shaft damage, or leaking shaft seal, the mechanical cooling fan assembly should also be inspected. Inspect for fatigue cracks, loose blades, or loose rivets that could have resulted from excessive vibration. Replace fan if any of these conditions are found. Also check condition of the thermal viscous fan drive. Refer to Viscous Fan Drive in this group.
The water pump can be removed without discharging the air conditioning system (if equipped)
REMOVAL
Disconnect negative battery cable from battery.
Drain cooling system. Refer to Draining Cooling System in this group.
Do not waste reusable coolant. If solution is clean, drain coolant into a clean container for reuse.
The thermal viscous fan drive is attached (threaded) to the water pump hub shaft. Remove fan/viscous fan drive assembly from water pump by turning mounting nut counterclockwise as viewed from front. Threads on viscous fan drive are RIGHT HAND. Using special tool spanner wrench 6958 with adapter pins 8346 and a suitable fan wrench loosen the fan drive Viscous Fan and Fan Drive Do not attempt to remove fan/viscous fan drive assembly from vehicle at this time.
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter.
If water pump is being replaced, do not unbolt fan blade assembly from thermal viscous fan drive.
Remove two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware Do not attempt to remove fan shroud at this time.
Remove fan shroud and fan blade/viscous fan drive assembly from vehicle as a complete unit.
After removing fan blade/viscous fan drive assembly, do not place thermal viscous fan drive in horizontal position. If stored horizontally, silicone fluid in viscous fan drive could drain into its bearing assembly and contaminate lubricant.
Remove accessory drive belt as follows: The drive belt is equipped with a spring loaded automatic belt tensioner. Relax tension from belt by rotating tensioner clockwise (as viewed from front) Automatic Belt Tensioner - When all belt tension has been relaxed, remove accessory drive belt.
Remove lower radiator hose clamp and remove lower hose at water pump.
Remove seven water pump mounting bolts and one stud bolt
CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
Remove water pump and gasket. Discard gasket.
INSTALLATION
Clean gasket mating surfaces.
Using a new gasket, position water pump and install mounting bolts as shown. Water Pump Installation - Tighten water pump mounting bolts to 54 N·m (40 ft. lbs.) torque.
Spin water pump to be sure that pump impeller does not rub against timing chain case/cover.
Connect radiator lower hose to water pump.
Relax tension from belt tensioner Automatic Belt Tensioner - Install drive belt
CAUTION: When installing the serpentine accessory drive belt, belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to Belt Routing for correct belt routing. Or, refer to the Belt Routing Label located in the engine compartment. The correct belt with correct length must be used.
Position fan shroud and fan blade/viscous fan drive assembly to vehicle as a complete unit.
Be sure the upper and lower portions of the fan shroud are firmly connected. All air must flow through the radiator.
Install two fan shroud-to-radiator nuts Fan Shroud Mounting Hardware
Be sure of at least 25 mm (1.0 inches) between tips of fan blades and fan shroud.
Install fan blade/viscous fan drive assembly to water pump shaft.
Fill cooling system. Refer to Refilling the Cooling System in this group.
Connect negative battery cable.
Start and warm the engine. Check for leaks
Jan 10, 2009 | 2000 Jeep Grand Cherokee
York Barbell  Home Use Fold-Up Treadmill Logo
18 people viewed this question
Top York Exercise & Fitness Experts
Mikee
William McDowell
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
