We tried connecting our laptop to our hdtv now the hdtv picture is blinking and won't stop?
  • 2,920 Answers
I would take the tv in for service before it gets any worse than it is now
Posted on Jan 25, 2009
Samsung HDTV no picture no sound
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 13, 2014 | Samsung UN22D5000NFXZA 22 In Led Hdtv...
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Nov 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Sony blinking codes
If i remember correctly ten blinks means a high voltage error.
The only thing you could try is unplugging the power cord then plug it back in and try turning on the tv. If it still won't turn on try unplugging the power cord for five hours or longer and try again. If it still won't turn on it would be best to find a local repair shop that works on sony tv's and have them repair it for you.
Mar 01, 2012 | Sony Grand WEGA KDP-51WS550 51" Rear...
Green light turns on for 1 or 2 seconds and then goes off. tv won't turn on, no picture.
Have you tried accessing the self diagnosis feature by pressing the menu and device buttons both together and holding for for 5 seconds? If not try that and let me know the error code. It will be a two digit blink sequence which will repeat a few times. Let me know what the blink sequence is.
Jun 07, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
Trying to import pictures to laptop. I have my camera with picture showing , and when I connect it to my laptop the picture disapears and in the corner is USB. Also, when I turn my camera on a orange...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 30, 2010 | Fuji FinePix J10 Digital Camera
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Sep 02, 2017 | Akai PTH5498 54" Rear Projection...
Tv won' turn on. Green light constantly blinking.
this tv is mitsubichi?
is mit what is the model?
look like bad DM, you need chage The capacitors.
Jan 31, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
