Question about Sage Computers & Internet
The report could not be generated. No data was returned for this report displaying, when I try to print remittance
2 Suggested Answers
SOURCE: Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Posted on Feb 19, 2010
How to print database in vb
To Print a Database you would require to create a Report. There were many ways of creating reports in Visual Basic 6.0. Hereby I am giving you an example of Data Report.
Printing a Data Report
Printing a data report can be accomplished in one of two ways. The user can click the Print button that appears on the data report in Print Preview mode (using the Show method), or you can programmatically enable printing using the PrintReport method. If an error occurs during printing, trap it in the Error event.
Choosing to Display a Print Dialog Box
When printing a report programmatically, you have two choices: to print by displaying the Print dialog box, or by printing without displaying the dialog box.
To display the Print dialog box
  1. Add a CommandButton to a Form.
  2. In the button's Click event, place the following code.
DataReport1.PrintReport True The Print dialog box allows the user to select a printer, print to file, select a range of pages to print, and specify the number of copies to print.
Note Printers must be installed on the computer in order to present a choice of printers.
Printing Without a Dialog Box
In some cases, you may wish to print the report without user intervention. The PrintReport method also gives you the option of selecting a range of pages to print, either all, or a specified range.
To print without displaying the dialog box
  2. In the button's Click event, place the following code:
DataReport1.PrintReport False
Or, to specify a range of pages to print, use the code below:
DataReport1.PrintReport False, rptRangeFromTo, 1, 2
Mar 11, 2014 | Microsoft Visual Basic 6.0 for PC
Pin code reached the copy limit. How to re-set the copy limit for pin code?
The Auditron feature is used to prevent the machine from being used by unauthorized users and also to track the total number of copies or prints produced with each account. When the total number reaches the upper limit set up by machine administrator, users cannot use the copy feature on the machine. Before resetting the machine you will want to print a usage report. Those instructions are at the bottom of these instructions.
  1. Press the [Log In / Out] button on the Control Panel. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the [Select] button below the Display Screen to select 'System Settings.'
  3. Use the numeric keypad on the Control Panel to enter the Administrator Login ID, then press the [Select] button to confirm.
    NOTE: The default System Administrator Login ID is set to 11111. The System Administrator mode allows you to customize many settings on the machine to suit your particular requirements. The machine enters the Machine Administrator mode only when a correct System Administrator login ID is entered.
  4. Press the [Select] button until 'Auditron Admin' is highlighted, and then press the [Enter] button on the Control Panel to confirm selection. The Auditron Administration screen will be displayed.
  5. Press the middle [Select] button until 'Reset Acc Limit' is highlighted, and then press the [Enter] button. The 'Reset Accounts' screen will be displayed.
  6. Press the left [Select] button to reset all accounts.
  7. Press the middle [Select] button to cancel the request.
  8. Press the left or middle [Select] button to perform the action. The Auditron Administration screen will be displayed.
  9. Press the [Exit] button to return to the default screen.
Solution : How To Print Reports and Lists (Auditron / Copy Meter Report) The Print Report / List feature allows you to print various reports and lists for each non-print job.
  1. Press the [Machine Status] button on the Control Panel. The Machine Status screen will be displayed on the Display Screen. See the Related Items below for additional information on navigating the Control Panel.
  2. Press the middle [Select] button below the Display Screen to display the Report / List information.
  3. Press the [Enter] button on the Control Panel. The Print Report / List (Non-print Jobs) screen will be displayed with the options referenced in the table below.
Copy Meter
Lists the account data such the account name, the limit set for the account and the total number of copies for each account.
  1. Press the [Select] button to scroll to highlight the required report under the appropriate column, then press [Enter].
  2. Press the [Start] button on the Control Panel. The Report / List will print.
May 16, 2011 | Xerox WorkCentre M118 Black and White...
How do I get a confirmation when a fax is sent
Press FUNCTION and DATA REGISTRATION.
Use the search buttons(^,v) to display 3. REPORT SETTINGS.
Press SET, then use the search buttons to display "TX REPORT"
Press SET, then use the search buttons to select "OUTPUT YES"
Press SET.
now exit from menu and whenever you send a fax a trasmission report will be generate automatically
Jan 06, 2011 | Canon CFX-L4000 Plain Paper Laser Fax
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
How to automatically import data from tally to excel. Want to display auto imported data in sharepoint.
Import TALLY Data / Export TALLY Data
Tally allows users to Import data from other software's as well as Export data from Tally to other software's. Tally allows users to Import and Export in ASCII, SDF and XML formats. XML is now the most widely used format of exporting data in the world. Any transactions can be exported from Tally and imported in other software after suitably altering the current structures to accept Tally data structure. The reverse is also possible by writing a small TDL program to accept the data from other software's. The data that is to be imported into Tally can be in either XML or DBF format. Easy Tally data transfer or Tally data migration from Tally 4.5 & Tally 5.4 to Tally 6.3 , Tally 7.2 , etc.
ODBC COMPLIANCE ALLOWS OTHER PROGRAMS TO USE DATA FROM TALLY DIRECTLY. E.G. : MS-EXCEL :
ODBC - OPEN DATABASE CONNECTIVITY
Tally is now ODBC compliant. Hence, any program like MS-Excel, Oracle etc that is ODBC compliant can use data from Tally. Here, data connectivity is dynamic i.e. any new updation in Tally is reflected in other ODBC Compliant Software immediately. Now, with ODBC facility the user can extract data out of Tally and design his own report formats in other ODBC compliant software's.
Procedure :
Now, Load Company -> specify period -> minimize Tally -> Open a new Excel file -> select data -> select 'Get External Data' -> select New database query -> choose Data Source
Tally connects to data source and displays Tally Wizard query screen -> select the columns you would want to include in the query.
Once all the columns are selected, the user returns to excel and excel displays all the columns selected
Graphical Analysis of Tally Data
Sometimes, pictures can say better than figures. Tally also provides graphical (Bar graph) analysis of data. The user can do a graphical analysis reports like Sales register, Purchase register, Ledgers, Funds flow, Cash flow, Item registers etc. This helps the user in deeper analysis of data. In Tally, a graphical analysis can also show month wise graphs for the year in comparison with any other period. This will help the management in quickly locating the highs and lean periods in a financial year and hence be better prepared for difficult times.
Web Enabled
Tally ees 6.3 is now Web enabled. This will help the user in reducing his paper work further. Now, report in Tally can be e-mailed directly from Tally. It is not just reports, but even invoices and purchase orders can also be e-mailed directly from Tally. Hence, the user does not have to send printed invoice or purchase orders from Tally.
Procedure :
Select any report (e.g. Balance sheet) -> select Alt+M (E-mail) -> specify all details as required by Tally
Ability to Publish Reports and Documents on the Internet
Now, Tally allows users to upload reports on the web site directly from Tally. So companies that would want to publish reports on the web site can do so directly from Tally. Many companies would also like to publish their price list on their websites along with the product they deal with.
Procedure :
Select any report (Profit and Loss A/C) -> select Upload (Alt + O) -> specify all details as required by Tally.
Direct Internet Access
Tally now offers direct Internet access. A Tally user while working on Tally can directly log on to tally website get details of all the facilities offered by Tally. The user can also download the latest releases of Tally 6.3 as and when available. Tally website also offers a facility of Tally Chat. Any user can now chat with a Tally representative and get any information regarding Tally.
Procedure :
Start Tally -> now, from any screen select Web Browser (Alt+W). Tally now takes you to the Tally Web site.
Print Preview
Any user would ideally like to view format of reports / Invoices / Vouchers before printing the same. Tally now offers a facility of print preview. Now any report can be viewed before printing or before it is mailed. Once Tally shows the preview the user can either opt to print or mail the same.
Apr 15, 2010 | Microsoft Office Excel 2007
What button do I press to generate a Fax report - this is not always generated automatically.
Sounds like your Fax Options are set to print on error only. If you want to have both confirmations and error pages do the following:
1 Press Menu until “Fax Setup” appears on the top line of the display. Press Enter.
2 Use the scroll button to find MSG Confirm. Press enter.
3 It may be selected to On-Err. Use the scroll arrow buttons to get to On. Press Enter.
4 To return to Standby mode, press Stop/Clear.
This should make your fax print out a confirmation on a successful or failure transmit of your fax.
If you want to print out the last few sent or receive faxes:
Printing a Report
1 Press Menu until “Reports” appears on the top line of the display.
2 Press the scroll arrow buttons to display the report or list you want to print on the bottom line.
•Phone Book: Phonebook list •Sent Report: Sent fax report •RCV Report: Received fax report •System Data: System data list •Scheduled Jobs: Scheduled job information •MSG Confirm: Message confirmation •Junk Fax List: Junk fax number list
3 Press Enter. The selected information prints out.
You can find your manual in English by clicking here.
------------------------------------------------------ Please rate this post if it helps you! :)
Dec 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
Tally9's features
Tally uses the latest technology to provide features in a simplified manner. It is a robust system that is easy to use.
Multilingual Business Accounting and Inventory Management Features
  • Multilingual Support: Tally can now be used concurrently in the language of your choice. Tally's interface is now available in Bahasa Melayu besides English and the Indic languages Hindi, Kannada, Bengali, Gujarati, Marathi, Tamil, Punjabi, Telugu, Malayalam and Hinglish (colloquial)
  • Payroll: Payroll in Tally enables users to set up and implement simple to complex salary structures. You can align and automate payroll processes and directly integrate them with main stream accounting applications. Tally Payroll also supports configurable formats for payslip printing; flexible salary/wage, attendance, leave and overtime registers; gratuity and expat reports
  • FBT (Fringe benefit tax): FBT in Tally is a one time, easy to enable configuration. It supports Challan management and printing for prompt and accurate filing of tax. On entering the transactions, Tally automatically calculates the FBT and generates the reports
  • VAT Composition Returns: VAT Composition Returns in Tally provides fast and error-free voucher entry with complete tracking of each transaction. It supports the printing of VAT Composition Returns of any state in which VAT has been implemented. The Composition Rate of VAT is automatically recognised based upon turnover and the tax payable is calculated automatically and shown in the Return Form
  • Excise for Dealers: Excise for Dealers in Tally generates Excise Invoices for Traders, Tracks Purchase Invoices during sales and duty credit availed and passed on. It also maintains the Excise Stock Register and generates Quarterly Returns
  • TDS (Tax Deducted at Source): Tally allows you to configure TDS ledgers by specifying the Nature of Payment and Assessee Types, along with the Rate of TDS. It determines user-defined expense/payment types with user-defined rates. TDS can be deducted automatically based on pre-defined rates, once the transactions exceed the threshold limit. You can generate Challans, the Form-16A Certificate as well as the quarterly and annual returns. Tally also generates e-TDS files in NSDL compatible formats
  • Synchronization: Synchronization in Tally helps you transfer data between two or more locations (Example: When a Branch Office and the Head Office of a company reside in two different locations). Synchronization can be done, both ways (For Example: You can transfer the data from Branch Office to Head Office or vice-versa).
  • E-mail reports and documents directly from Tally
  • Publish reports in HTML on Web or Intranet and share them with suppliers, customers or your own staff
  • Direct web browsing capability from within Tally that avoids switching between programs
  • Exchange data with other systems using XML. Tally gives you the means to collaborate with others and share information like never before
  • ODBC connectivity opens up Tally. This makes Tally fields in ODBC to be compliant with programs like MS Word and MS Excel. This enables you to integrate Tally data dynamically into other ODBC systems. It even designs a form like remittance advice and imbed fields like Customer name and address, account balances and so on, in Excel/word
Jul 11, 2009 | Tally Intelliprint ML450 Laser Printer
Line 50.
then press ENTER.
Jul 07, 2009 | Sage Computers & Internet
Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Jun 14, 2007 | OKI MICROLINE 520 Matrix Printer
Computers & Internet Logo
268 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
ray gallant
richie46
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
