Question about Acer Aspire Computers & Internet
Manual or diagram showing how to hook external cables back in correct place
Acer aspire M1100 AM1100 motherboard mbs88090018090169 4gig
    Problem Solver:
  • 14 Answers
Did U meant to hook the cable to keyboard,mouse etc back to the backplate?? or the cable on the motherboard itself?? i cant get your questions enough..please be specific..TQ
Posted on Feb 09, 2013
siawolf
  • 749 Answers
SOURCE: I need help! I'm
here is what you will need to complete this project:
  • Your new DVD burner with the included screws and cable.
  • A phillips screwdriver.
  • your new harddrive
  • Once you unpack the drive and find a screwdriver, you can finish the prep work by turning off and unplugging the power from your PC.
Installing Your Harddrive Step1 Open up your case after backing up any important files and locating and installing any software that came with the hard drive. Check to make sure that your computer supports SATA or that you have a SATA PCI card installed. Step2Look for the smaller connector on the SATA cable and connect it to the SATA connector located on the motherboard or controller card. If you already have another SATA drive, simply follow its cable to the motherboard or card to see where this one will attach. Step3Grab the larger end of the SATA cable and connect it to the back of the SATA drive itself. You will also need to attach the legacy 4-pin connector or SATA power cable to power your drive. At this point, check to see that both the smaller and larger end of the SATA cable and the power cable are securely connected and proceed. Step4Choose an available drive bay and insert the hard drive into it, mounting it in place with the four screws provided. Make sure to follow the directions that came with your drive and place the screws in the designated holes to secure proper grounding. Step5Ensure that all cables are properly attached and replace the tower or desktop case cover. After doing this, you're all set to reconnect the power cord and turn on your computer. Formatting and Partitioning Step1Boot from your Windows CD. If this is the only hard drive present, you'll be shown a series of instructions and should simply follow along. Step2Select "Control Panel" then "Performance and Maintenance" and finally "Administrative Tools" for an additional hard drive. Then click the "Computer Management option and choose "Disk Management." Simply right-click the drive to partition and format it. Step3Follow the steps displayed. Windows will guide you through the rest of the process. Now for your dvd drive---- 1.Shut down the system, unplug the power cord and remove the side panel or panels from the case. Ensure that the new DVD-ROM drive is set to be "Slave" or "Master," depending on if it is a replacement or an additional drive. 3 2.Locate the empty drive bay for the new DVD-ROM drive, and remove the drive bay covering. 4 Insert the new DVD-ROM drive into the empty bay and secure with screws or other attaching device provided by the manufacturer. 5 3.Connect the open connector on the ribbon cable (red stripe towards power cable) to the new DVD-ROM drive and connect the power supply cable (plastic four connector plug from power supply)to the drive. 6 Replace the side panel or panels, plug in the power cord and turn the system on. Install your dvd software bundle and get to work. These are actually two things you will want to do at once while the computer is open , but i would do them one at a time in case you have problems you will know what to blame. You can leave the cover off while operating the computer so that you can test it after the hard drive instrall and before the dvd install.
Posted on Oct 21, 2008
  • 70 Answers
SOURCE: Aspire M1100 boot up problem
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
1. Use the Windows XP CD-ROM to start your computer.
2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
3. Select the Windows installation that you want, and then type the administrator password when prompted.
4. Type bootcfg /rebuild, and then press ENTER.
5. When the Windows installation is located, the following instructions are displayed:
Add installation to boot list? (Yes/No/All)
[Type Y in response to this message.]
Enter Load Identifier:
[This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
Enter OS Load options:
[Leave this field blank, and then press ENTER].
After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
2. After the setup files are finished loading press R to repair using Recovery Console.
3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
4. Login to the Administrator account by typing the password for this account, and then press ENTER.
5. At the recovery console command prompt, type the following command, and then press ENTER:
For Uni-Processor systems:
expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
For Multi-Processor systems:
expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
6. If you receive a prompt to overwrite the file, press Y.
7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Posted on Jan 11, 2009
  • 987 Answers
SOURCE: motherboard driver
http://support.acer-euro.com/drivers/desktop/aspire_m1100.html
HERE U CAN DOWNLOAD DRIVERS..
Posted on Mar 03, 2009
  • 48 Answers
SOURCE: Acer AM1100-E1401B
Try Acers website first and then try driverguide.com
Posted on Apr 10, 2009
splintellz1
  • 37 Answers
SOURCE: Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Posted on Jul 03, 2009
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
I disconnected all cables inside acer aspire m1100-am1100-b1300a i need manual or diagram to reconnect not familiar with newer type cables
There is a problem,the first thing U should do before disambled anything...take a photo first in its original conditions,event an expert still backup with photo to avoid anything wrong in future..so here i think we need a photo of your motherboard to help you..ACER really smart,they dont want us to D.I.Y its product..and they want us to send the malfuncions product ti their services centre..there is no manual / diagram of that mobo..and they also smart to hide the part number of their mobo...so what u can do now is upload a photo of your mobo to some photo hosting website..and wait somebody to look for it..thats what i can say..TQVM
Jan 18, 2013 | Acer Aspire Computers & Internet
Why do not restored disks work for Acer Aspire M1100?
Turn off the computer Henry then turn it back on and hold down the alt key and tap F10 and make sure you remove any disks from the CD drive.
It would appear that the hard drive is having boot sector issues.
http://www.ezsystemrepairs.com
Nov 08, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
Acer aspire m1100 desktop getting a no signal on monitor, how do I get my pc to open
My Acer Aspire M1100 would not boot and had no signal to the monitor. I thought the video card or motherboard had gone bad. I tinkered with it for over 2 years (yes I'm hardheaded) and finally realized the processor had worked itself loose. Reseated the processor and it works fine again. Hope this helps someone.
Jan 04, 2012 | Computers & Internet
How to rewire the motherboard
Download this service guide for Acer Aspire Desktop PC -->click HERE!
This manual will guide you to rewire the motherboard .
Jan 09, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
Where is the cmos battery on an acer aspire 8920 and how do I change it.
Before you start
1) Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
2) Purchase the battery through Acer or a local or online computer parts dealer.
3) Turn the laptop off and unplug it. Also unplug any external hard drives, cameras, or other external devices.
4) Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal of the CMOS battery
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery.
The battery should look something like this
slasher_x_0.jpg Plugging the new battery in
Plug the new CMOS battery cable into the motherboard. Slide the battery partially under the laptop casing (somewhere to hold it in place), then align the cover with the slots on the bottom of the laptop housing. Replace the screws then turn the laptop back over.
Finalizing
1) Turn the laptop on.
2)Enter your BIOS (usually by pressing the "Delete" key) before the operating system loads.
3) Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
Reason: Anytime the CMOS battery is unplugged for more than a few seconds your BIOS will be reset to the default manufacturer settings. If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3 to 5 seconds to correct the problem.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Nov 12, 2010 | Acer Aspire 8920-6048 Notebook
Motherboard acer A1100-B1300A.... ????
Knowing the model of the mobo will not do anything if you know it takes
DDR2 5300.
And you can find tons of 1GB,2GB,4GB sticks.
If you want to know what memory MFG are compatible with you system
go to the Acer website.
As you can see at the website I posted below there are a lot of memory you can get.
Here are 12 different brands of 5300 2GB sticks of memory.
If your sure the motherboard takes 5300.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010170147%201052408745%201052307859&name=2GB
Feb 08, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
Acer AM1100-E1401B
Apr 09, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Computers & Internet Logo
198 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
