Question about Motorsports
Easyiest way to change a 4'3 vortec in a 98 s10 blazer
  • 1,615 Answers
Http://www.youtube.com/watch?v=gT5rjk4cBFk will show you how to do it.
Posted on Dec 04, 2013
I have a 02 blazer i want to put a motor out of a 98 in it will it interchange
Chevy Blazer Engine Swap Part 1 of 2 - YouTube
? 10:29
https://www.youtube.com/watch?v=Dt_7AKP2WcI
Aug 13, 2011 - Uploaded by Dave R
Replacing the engine in a mid-size Chevy Blazer 4x4 with oneout of a Jeep Cherokee 2wd. Original engine was low and motoroil and spun a bearing. ... Chevy Blazer Intake Gaskets Replaced & Cooling System Rebuilt - Duration: 16:45. by ... 4:02. 94 4.3l Vortec V6 GM (black motor) - Duration: 6:01. by ...
4.3 vortec engine removal - YouTube
Jan 01, 2016 | Cars & Trucks
I have a 2003 Chevy blazer with a 4.3 vortec motor it has a small leaking head gasket how long can I drive it until I have the money to fix it.
Troubleshooting a Blown Head Gasket (GM 4.3L, 5.0L, 5.7L)
troubleshootmyvehicle.com > GM > 4.3L, 5.0L, 5.7L
Mar 28, 2011 - There are so many ways to test for a blown head gasket on your 4.3L, 5.0L, 5.7L GM van (or mini-van, pick up, SUV) that it can get confusing.
Chevy Blazer Coolant Leak (Intake Manifold) - YouTube
? 4:33
https://www.youtube.com/watch?v=SC4VXdt5wiE
Oct 9, 2013 - Uploaded by eyetotheworld
I have localized a coolant leak on my 2003 Chevy Blazer to thegasket of the intake ... Turns out that this is common among this particular engine both in the v6 & v8 sizes. ... The guy has been generous to detail his projects. ... 98 S10 Vortec V6 4.3 IntakeGasket Replacement Part 1 of 5 - Duration: 18:17. by ...
Chevy 4.3l v6 oil leak issue 2001 Xtreme Blazer - YouTube
? 6:11
https://www.youtube.com/watch?v=Y8Ogd5voIYs
Nov 12, 2011 - Uploaded by smiatacz
This darn little engine just keeps going. ... I have a 2003 chevy blazer and the oil cooler line from the oil filter to ... I have a 95 Chevy s10 v6 vortec 2wd that is slightly dripping oil out of agasket ... I'm having same problem 2001 Chevy Blazer 4x4 (not xtreme) not sure if those same bolts are missing on mine.
Dec 28, 2015 | Cars & Trucks
93 s10 blazer with 4.3 liter vortec won't stay
You first need to run a fault code test on this engine, to do that go here.
Oct 10, 2012 | Cars & Trucks
95 S10 blazer 4.3 vortec skipping code po172 and po300 possible solutions
P0172 system too rich bank 1. P0300 random multiple misfire. All are a common symptom of either bad fuel pressure regulator or leaking injector. Need to pull off intake plenum (upper) You should visibly see a clean side or part of intake manifold (lack of carbon buildup) Reconnect fuel lines. Energize fuel pump (turn on key to run) Most likely you will see fuel dripping out of rear (fuel pressure regulator) or nylon lines to each cylinder (fuel injectors). Once you see which is leaking will need to replace. Once they are repaired will need to clean or replace spark plugs & change oil & filter.
Jun 26, 2010 | 1995 Chevrolet Blazer
S10 Blazer 4.3 to a 350 FI
If you live in a state with smog license requirements your wasting your time, the engine has to meet EPA requirements for the year vehicle was manufactured your car is considered a clunker good luck getting it smogged. And it is no big deal to change. 350 is almost identical to 4.3 just some variations.
Aug 20, 2009 | 1994 Chevrolet S-10 Blazer
89-98 chevy blazer
It's not worth doing all that conversion, buy the time you spend the time and money to convert the 89 4.3 to work on the 98 blazer, it would be cheaper to install a 98 vortec rebuild. The 89 4.3 have a TBI fuel injection system and the ecm on the 98 will not work and the bad news is that the ecm on the 98 also controls the transmission shift points and the 89 will not, so even if you swap the ecm to have the 89 4.3 engine work. the transmission will not shift. Sorry for the bad news but it would be cheaper to replace the 98 engine with the years of 1996 to 2001. Good luck and hope this helps.
Jul 21, 2009 | 1989 Chevrolet S-10 Blazer
I have a 1994 S10 with 4.3 Vortec. Sometimes the motor will stall, like it does when it reaches 98 MPH. It may do it on take off, or with the cruise on.
IM NOT CERTAIN WITH OUT CHECKING IT BUT HAVE YOU CHECKED FOR CARBON BUILT UP IN THROTTLE BODY OR IT BE ENGINE CONTROL MODULE... LIKE I SAID CANT BE CERTAIN OR MAYBE PUT A SCANNER ON IT .....
Jun 26, 2009 | 1994 Chevrolet S-10 Blazer
Will a 98 s1o 4.3 vortec tranny fit in my 98 1/2 ton with 5.7vort
unfortunately, this is not possible. you could force it but, i wouldn't recommend this at all.
Mar 13, 2009 | 1998 Chevrolet Blazer
Motorsports Logo
108 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
