Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Whirlpool gu1100xtlq1 stopped running no power I found that the board in the door was fried and replaced it. Is there a reset switch somewhere? it still doest run
  • wcrumley Mar 08, 2009
    stopped running, nothing will light up. I finally got the drain to light up and run for a couple of minutes now nothing works. Have good power coming in. Help!
    President:
  • Whirlpool Master
  • 2,651 Answers
The white fuse mounted to the circuit board may have also blown out. real common occourance id check that first
Posted on Jan 26, 2009
Dryer not powering on
The second frying of the switch indicates a major problem somewhere. Start at the receptacle and work your way back to the inside of the dryer and see that everything is tight. I think you will find that the problem lies at where the wire ends at the block inside of the back of the dryer. This might be ugly. Dryers conduct a lot of heat and electricity and can be safe if wired properly. Your breaker may need to be reset. Turn it off and then back on to get it to start up.
Feb 22, 2013 | Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric...
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
My whirlpool dryer will not start
OK, check the following areas to combat this no start issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
If all the above checks out ok, replace the timer or control board.
Jun 14, 2009 | Whirlpool LER5636P Electric Dryer
Won't turn on
CHECK THE FOLLOWING----
3. Thermal fuse
4. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Dryers
10yr old bryant 90 series
Something is shorted out somewhere in the system.
You will have to trace down each component to find the short if it can't be found with a visual inspection.
Does the board have a low voltage fuse on it?
Dec 17, 2008 | Kitchen Appliances - Others
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool clean light flashes 7 times
Actually, the button order to put it in a diagnostic cycle and clear the blinking clean light on the gu2500 is HEATED DRY, NORMAL, HEATED DRY, NORMAL not the other way around as Iden had posted.
Mar 27, 2007 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
631 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
