Question about AEG Dishwashers
I need fixings & a template for an aeg favorit 35085vi dishwasher
I purchased an AEG favorit 35085vi dishwasher form homebase last year but when i've come to install it in the new year it has come with no fixings or a door template. I've been back to Hombase for the kit but have been informed I must contact AEG. On contacting AEG I was informed that there was nothing they could do for me & I would have to purchase the fixings & template seperatley. i'm more than dissapointed with both Hombases & AEG lack of help & wondered if any body new of anywhere else I could obtain the kit I need to finish my kitchen off
SOURCE: Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Posted on May 22, 2007
SOURCE: Ontegrated dishwasher door fitting
Just fitted on of these & found the door very easy to fit.
The instruction sheet is actually a template as well. Attach it to the back of the door & where indicated drill 2mmø holes to a depth of 14mm. Firstly then screw in the 2no. screws that go into the door slots, the actual screws are easy to spot as the screw thread finishes approx 5mm from the head.
Once that is done you need to offer the door to the front of the dishwasher & slot it into place. Once done you have to fix the door in place with the 6no. longer screws. To do this you must remove 4no of the screws which are holding the front of the dishwasher together, the other 2 screws go through empty positions at the bottom of the dishwasher door.
To help with this process I would recommend you use a soft jawed clamp to hold the door in place whilst you screw it in place.
There are also 2no. angle brackets that fit into 2 slots on the top of the dishwasher which are then used to hold the dishwasher in place under the work top.
Hope this helps.
p.s. one last thing, the thin strip of steel that comes with the kit fits onto the underside of the worktop in the position shown, I believe this is a steam deflector to protect the underside of the worktop
Posted on Nov 10, 2008
SOURCE: AEG Favorit 40650 dishwasher is
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
Posted on Nov 11, 2008
BIKER T
  • 909 Answers
SOURCE: AEG Favorit dishwasher AAA shows Error code 10
Normally if washer doesnt complete cycle, its because the element has tripped the over temp.th/stat.(underneath), or is faulty. otherwise 1 of the 2 boards are faulty. Often the board at the bottom front left.(behind the kick panel.)is the issue. Roaches seem to accumulate on the bottom board and disrupt the circuit. If you have a mechanical timer, wiggle it side to side and note if there is a difference.
Posted on Sep 16, 2009
TheMazz
  • 78 Answers
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 17, 2009
Testimonial: "very quick, thankyou"
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Favorit 35085Vi - possible cause of anti flood system being triggered?
It can only be due to a leak running into the base. Suggest you remove RHSide cover and run washer.again. Inspect while running and see where leak is comming from. My guess, its the main motor.
Sep 21, 2009 | AEG Dishwashers
AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Feb 17, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwasher fail on C3 (leak prevention system)
http://www.kunnig-elektro.de/reparatur/spuelen/aeg/zulauf2.html
in German ... anyway a couple of pictures :)
Dec 15, 2007 | AEG 24 in. Favorit 50730W Free-standing...
Dishwashers Logo
99 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
