Question about Whirlpool LSQ9600L Top Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
Washer agitates but clothes are not moved towards bottom to be agitated. clothes mover is loose.
  • 130 Answers
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Posted on Jan 26, 2009
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore Series 80 washer. Agitates too slow
check the dogs in the agitator take off the cap it should rachett if it turns free replace the dogs in the agitator
Jul 12, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator only works on bottom half. can I repair
if the clothes mover section on top quit,remove the detergent cup and with a 9/16" socket remove the bolt down inside,this will let you remove the clothes mover part,then you need to order the thrust bearing and dogs cam rebuild kit for this model
Mar 23, 2010 | Kenmore 22422 Top Load Washer
Whirlpool washer does not agitate/wash but the spin cycle seems to work. I've found that the bottom section of the agitator blades are turning but the top section does not turn. I can also turn the top...
The problem that your washing machine is not agitating, you will need to check certain things.
Please check the timer to see if it is in good working order or not. Next you will need to check the motor and the motor switch. On some of the newer washers the door switch also controls the motor.
If the motor starts running after the washer has filled to the selected level, but the agitator doesn’t move, you will need to check the following parts.
The agitator dogs. They are located inside of the agitator clothes mover. You will need to remove them and check to see if they are in need of been replace.
The clothes mover. This part is the top part of the dual action agitator. Its job is to move the clothes from the top of the spin drum to the bottom part of the agitator.
You will also have to check the inside of the clothes mover to make sure that the gear like cuts are not worn out.
However another problem could be a broken motor coupler.
Thank you for contacting Fixya.com
Aug 09, 2009 | Whirlpool Washing Machines
Agitator seems loose and agitates during the spin cycle
HI, the actuator shift device in the transmission is malfunctioning. you will need to replace the transmission soon.
May 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator gear is stripped
just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Top agitator doesnot work
Your agitator dogs are worn out. They are 4 small pieces in the agitator that act as one way clutches. They allow the top section to turn one way but catch the other way. Pretty simple fix.
If you will post the complete model number I will find the part numbers for you and try to provide instructions on replacing them.
Nov 26, 2007 | Whirlpool LSB6200PQ Top Load Washer
Whirlpool LSQ9600L Top Load Washer Logo
571 people viewed this question
Dan Webster
Dan Webster
Sal De
