Question about Ignition System for Mercedes-Benz C230 Sedan
Ignition key wont turn - Ignition System for Mercedes-Benz C230 Sedan
    New Friend:
  • 60 Answers
Wrong Key? or Worn key wiggle it up an down when trying to turn it...
Posted on Jan 22, 2013
I cant start the car the key wont turn in ignition
Last time i had this problem, my car wasnt all the way in park, so what i would try is:
1: apply the break
2: push up on the gear shift, to make sure its in park.( if you can move the gear out of park, move it all the way to drive 2, then back to park.
3: try the key again
Aug 01, 2016 | 1995-1996 Saab 900s Convertible Top Cover
Key wont turn ignition and steering wheel also locked
Turn the steering wheel anticlockwise or to the left and turn the key.
Jan 07, 2014 | 2007 Hyundai Atos Prime
Key wont turn in ignition
If another key works look for a small difference between keys. Sometimes a key is cut high or low. If no key works in the ignition then it could be the tumbler.
Dec 29, 2013 | Mazda Protege Cars & Trucks
Key wont turn in ignition. Dont want to hear the key is bent. Tried everything to get it to turn, but wont. It happened earlier today and after 20 minutes of giggling the key it finally turned over. ...
The problem can only be one of three things. Steering column, ignition or key. When there is tension on the steering wheel it will prevent the key from turning. If the linkage in your ignition is bad it will prevent it from turning. If your key looks worn or marred (it doesn't always have to be bent) it wont turn.
Jun 15, 2011 | 2000 Mitsubishi Montero Sport
KEY WONT TURN IGNITION
Your car uses a transonder key, a key with a small chip embedded inside. The transponder is matched to the immobilizer unit in your car. When the key is inserted into the ignition, the immobilizer searches for that transponder, if it's not near the ignition, the car will just keep turning over and not start. Your only real options are to replace the steering lock or buy a transponder bypass unit, which I do not recommend. Just do a google search.
Aug 09, 2009 | 2003 Honda Pilot
is it correct key? key and ignition barrel could be worn wiggle key around in ignition while turning? gently but fast wiggling.try lube in key slot also.
if not replace barrel and key
May 31, 2009 | 1995 Toyota Camry
1998 buick lesabre wont start
Do you have a Chip in the Key? if so that Could be the Problem,Ya see the chip is a resistor and if it looses its ELECTRONIC VALUE in its Case Resistance it wont start to test this Turn the Key in the ON posission then do the Screwdriver thing If it Starts Key is Good and Most Likely the Ignition (SWITCH) is Bad <<ELECTRICAL Side NOY LOCKEST SIDE For More Info Recontact Me
rejakwilson@aol.com<<<<<<<<<<<<<<<
Dec 23, 2008 | 1998 Buick LeSabre
Key wont turn to Ignition point
you need to buy a new ignition tumbler
Dec 14, 2008 | 2000 Volvo S40
Ignition System for Mercedes-Benz C230 Sedan Logo
77 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
