Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e-studio 600 copier machine displaying error toner not recognized
  • 10 Answers
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
Posted on May 19, 2009
  • 4 Answers
SOURCE: Empty used toner not clearing
you have to go into service mode and reset counter.in your manuel
Posted on Jan 04, 2009
  • 990 Answers
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Posted on Jul 20, 2009
  • 10 Answers
SOURCE: Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Posted on Nov 06, 2009
E studio 256 not recognizing toner. how to remove this error. -
Check the toner bottle position, replace it, and/or clean the contacts in the machine where the toner botlle is going into.
Jun 25, 2016 | Toshiba E-Studio 256 Digital Copier
Hello sir copier Toshiba e studio 600. when I turn it on it shows 19 vertical lines standing in the screen display. Also it is still warming up .it makes me not able to copy . Please help me. Thanks
Display panel is properly shot. as warming up. try taking the toner bottle out after powering off. then power it on without he toner bottle let it go thru its cycle when asks for toner install
try this site for additional info
Toshiba STUDIO 520 523 600 623 720 723 850 853 Service Manual free...
Oct 19, 2015 | Toshiba Office Equipment & Supplies
E studio 256 not recognizing toner. how to remove this error. there is a new toner cartridge.
1. Make sure genuine toner is use
2. Toner chip not dirty
3. Toner detection inside the machine not dirty
Aug 23, 2015 | Toshiba E-Studio 256 Digital Copier
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
E studio 600 error cod f 105 how can reset
sir i have a toshbia estudio 600 the copy is coming light but i put the toner manually in the developer tank the copy is o.k. toner is full and the developer also new
Dec 01, 2013 | Toshiba E-STUDIO 650 Copier
Error code CF70 on toshiba e-studio 600
toshiba e studio600 error codes cf 70
Jul 20, 2012 | Toshiba E-STUDIO 650 Copier
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
My company have 2 unit photocopier machine model TOSHIBA e-studio 600...now this 2 unit have a same problem (display CD30)..what is the meaning of CD30...could u please help me...
CD30 shows that the waste toner on the recycle unit is full. U need to dispose it. Open the front cover, take out toner drive, take out the 2 covers, and u will see the recycle unit.
May 25, 2011 | Toshiba E-STUDIO 850 Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
79 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
