Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Hitachi 51swx20b - Blue shadows - horizontal blue lines are bowed
What is the part number to replace the convergence IC for a Hitachi 51swx20b?
  • 101 Answers
IC M62501P Hitachi Part Number: CP07091
Posted on Jan 25, 2009
  • 10,515 Answers
The part no. is
AA95-01799G
Thnx.
There are blue shadows around heads, much of the print is in yellow
The tv have a problems known as Convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Aug 20, 2010 | Hitachi 51SWX20B 51" Rear Projection...
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 43FDX01B Convergence Problems
Hitachi remote part # HL01643........I like the original remote
to do adjustments.................T.
Aug 06, 2008 | Hitachi 43FDX01B TV
Hitachi 55inch projection tv with blue shadow.
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
May 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 65xwx20b convergence
Your message says you "replaced stk392-150", did you replace both of the stk`s or just one of them??? One is for RGB vertical the other is for RGB horizontal, you should always replace both stk`s as a set, Hitachi recommends you use a "replacement kit"
part number X480306", this kit includes both stk`s with a new & supposedly improved set of stk`s as well as all resistors that are required for proper set-up, they strongly recommend you change all of the parts in their kit. The only other thing besides IC`s & resistors that could cause your problem is:
1) bad dcu output (you need a scope to check this)
2) you`ve lost either the +15 volt line or the -15 volt line to the IC`s, "Fxxx" chemical fuse open in power supply.
Dec 01, 2007 | Televison & Video
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 46in rear pro
You have bad convergene output IC's. There are 2 in the set and we always replace them both because the one that s not bad will likely fail in ashort time causing you to have a 2nd labor bill.
Aug 27, 2007 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
