Question about LG 32LD320 32 HDTVReady LCD TV
Does the usb port on lg 32ld320 play movies
THERE IS NO USB SYMBOL OPTION SHOWING ON THE MENU
SOURCE: usb harddisk problem on LG 50PT81+ not compatibel XP
LG have created a solution that only allows you to backup to a hard disk in the format that they have created.
The hard disk can not then be read by a computer as they only recognize formats such as NTFS, FAT or FAT32: not LG´s format!!!
If you reformat the disk in FAT32 format then you can copy files to the hard disk and see your photos, or certain types of DIVX files and listen to music via your TV,......BUT...you can not save TV programs from the TV to the same hard disk UNLESS you allow the TV to reformat the hard disk to LG´s format ) in which case you will lose all the files you previously had on the hard disk.
In practice LG have created a backup solution that is of little use to most users particularly bearing in mind that the backup takes almost as long as the original programs and as long again to restore.
Most of LG´s products are very clever and have a tendency to be in advance of the market.
However on this occasion LG almost had a good idea but many users are going to feel tricked like I did,
Posted on Mar 09, 2008
SOURCE: usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
Posted on Mar 12, 2010
Obertelli
  • 3006 Answers
SOURCE: I plug in the USB
First, try using a different USB stick. If that doesn't fix the problem then your new tv is either faulty or the tv operating system has a bug.
Check the LG website in your country to see whether there are any firmware updates available. If not, then return the tv for refund or exchange, but make sure to try your USB drive on any replacement set in store as it's highly likely to be a bug in your model which will affect all of the other examples as well.
Posted on Sep 22, 2010
natzki
  • 124 Answers
SOURCE: My lg lcd tv has a usb port but only recognises
You need to activate it first, here are the steps:
1. Press the enter(OK) both on the remote and the TV at the same time...hold for about 5 seconds
2. Password - 0000
3. Go to tool option 3
4. Change Jpeg to 1
5. Change Divx to SD or HD
6. Exit and try it out.
You will notice that now there are 8 inputs in the option list instead of 6 - Including a USB input.
Hope this helps
Posted on Nov 04, 2010
SOURCE: I have the lg 42ld450
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Posted on May 09, 2011
What are the steps to activate movies from usb port on my lg 50pg60ud model
The Pg series cannot play movies from Usb they have no processor for that
The first to have this were the Pq and then you could do this kind of hack
Sorry
Aug 17, 2014 | LG 50PG20 50 in. Plasma HDTV
Tip
How to activate USB on LCD TV LG's latest generation (LH2000, LH3000, LH4000)
When I got the TV, the LG LH2000, with a diagonal of 32 inches, I was a little disappointed when I realized
that the model that I bought does not work behind the USB port on your TV . I was explained that it is only
for service (software upgrades and the like). I did not beat your head too much and I accepted the
situation.
What would help me? I miss writing movies on CDs and DVDs. Copy just the files on a USB stick, insert it
into the port behind the TV, go into menu and select USB. It's like a DVD player. These days, I discovered
that I can retire the DVD player, because now I can enable the USB and still use it. How?
In a few easy steps.
1.Press the same time the OK button on remote and OK button on the TV and hold down for about five-six
seconds
2. Asking a password - using the buttons on the remote, enter 0000, then press OK
3. Upper left corner of your screen will show the service menu
Well, here's a little more complicated and should be recommended to strictly limit yourself to three
settings below. WARNING! Where do additional settings without knowing exactly what use, you are solely
responsible for the potential disruption of the TV and also for the possible loss of warranty!
Once the service menu appears, select the third option (number 2, named TOOL OPTION3). Do not confuse 2 with
3. The numbering starts with 0, not 1, will therefore TOOL OPTION3 will be numbered with 2.
In other words, select the option marked in yellow as the image on the right. I suppose you can select with
OK, but I entered in navigation settings press the "right" button on the remote.
Following two settings:
1. Once entered in the TOOL OPTION3 menu, select the EMF (JPEG, MP3) and using the "right" button of
navigation on the remote (to be clear, "right arrow"), select option 1.
2.A second, and final setting is highlighted in yellow in the image on the right. At DivX choose HD.
And now important!, In any form do not press OK from the remote! Press Exit button(Return), located in the
lower right-hand navigation menu.
What happens after these settings have been made? In TV menu will be two new options: Input and USB. We are
interested, at present, USB. What should I do to see movies? In this order:
1.Introduce stick into the USB port on the back of the TV
2.Press Menu button on your remote and select the USB
3.Select movie files (or something like that, anyway you got options for MP3 or photo)
4.se will open a variety of browser, similar to those on DVD players
5.Search for desired movie and press OK
Integrated player in LG television support DivX. I put a stick on an episode of TopGear and I saw with no
problem. Using left-right arrows, you can run the movie. For a typical player buttons (Play, Pause, Stop),
they use those colors (they are marked otherwise) on the remote.
Enjoy.
on Jul 20, 2010 | Televison & Video
TV is not showing the USB data
maybe you did not properly select the right application in your tv... example if you play movies go to movies menu and if thats music go to music menu and also for pictures go to picture menu......or the format of you data is not supported of you TV..
Jan 12, 2014 | Computers & Internet
USB port on LG DN898 Isn't playing movies from flash drive. TV screen is showing that the USB port is being used but no files are showing and nothing else is happening.
certain files are NOT register from DVD, you must read your instr.manual. The format is not support, you must convert your movies and know format from your DVD accoring in your instru.manual download the instr.manua. go to www.fitness.manualsonline.com or www.retrevo.com
God bless you
Jul 20, 2012 | LG DN898 DVD Player
Hello, How can I activate the USB port for my TV LG 32ld320-za? thank you... bye.
Hello
[1] Connect the USB device to the USB IN jack on the side
of TV.
After connecting the USB IN jack, you use the USB
function.
When you connect a USB device, this pop up menu is displayed automatically.
When the Pop Up menu does not appear, you can select Photo List or Music List in the USB menu.
In USB device, you can not add a new folder or delete the existing folder
[2] Select PHOTO LIST or MUSIC LIST.
[3] Press enter.
Jul 28, 2011 | Televison & Video
Usb problem lg pq2000
Feb 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Can I play my Ipod on my Lg tv through the ipod
Not if the USB port on the TV says "SERVICE" next to it. At least I don't think that it would work. But go ahead and try it. It can't hurt anything.
Plug it in and toggle through the input modes to see if there's an extra one showing your Ipod. Or look within the MENU settings to see about turning on or accessing the USB port as a video input.
Dec 05, 2009 | LG 32 in. LCD TV
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
Sep 11, 2008 | Yahoo YDP305 DVD Player
LG 32LD320 32 HDTVReady LCD TV Logo
596 people viewed this question
Computer Repairing
Computer Repairing
