We have a intertherm gas fireplace unit..model BDM35 and it is installed in our new home. Stone is on and everything. We had it stored for years so even though it is an older model it is new. We used it a few times and it burns black. Come to find out it is hooked up for natural gas and we have propane. I have tried everywhere to get a conversion kit for this unit. Please help.
SOURCE: LP Conversion Kit?
I'm looking for the same thing! My kitchen is covered in black soot and the inside of my new oven is BLACK!!!
Posted on Jan 06, 2008
SOURCE: natural gas conversion
I have a similar problem. But, I want to convert it to propane. I have a 5 burner vent free modelMN300HPA. If your are handy. I would consider shipping you the parts inside mine to install in yours. These parts are very simple to remove after removing the access panels. I have taken mine out already. Called procom then to no less find out the propane parts needed are not sold by them. I think only the injectors (5) the main valve (regulator) and the pilot are the only things need to change. When taking out the pilot this is easly done, By removing the nut on the supply line. And then bending back the retaining tabs to then slide back the pilot then it comes out of the assembly bracket. Injectors are simply removed. Regulator located at the bottom is a simple remove. The only other item that might be questionable would be the valve that selects the amount of burners you would like to operate. And I would think this would be the same and not need removing. Let me know if I can help. I would like to get mine converted to propane. Thanks Tom
Posted on Nov 06, 2008
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
huuum
  • 750 Answers
SOURCE: JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Posted on Jan 31, 2009
Looking for a picture diagram of a Bm36Hc fireplace
[PDF]deluxe 36 manufactured home fireplaces - Hansen Wholesale
www.hansenwholesale.com/images/fireplaces/.../Intertherm_BM36HCII.pdf
36" Wood Burning Fireplaces. P/N 800,019M REV. B 04/2002. BM36HC. BM36HCD..... Refer to the minimum system height chart. WARNING: DO NOT PACK ...Missing: picture
Intertherm BM36HC Installation Instructions Manual
www.manualslib.com > ... > Indoor Fireplace > BM36HC
View and Download Intertherm BM36HC installation instructions manual online. DELUXE 36. BM36HC Indoor Fireplace pdf manual download.
Dec 20, 2015 | Heating & Cooling
Intertherm fireplace model bdm35
Check the thermocouple, it generates the electrical power from the flame of the pilot to open the gas valve.
Dec 10, 2013 | Heating & Cooling
you must download the code go to www. remotecodelist.com or use your code from you owner manual download from www. retrevo.com
and follow the steps for to do it again.
God bless you
Nov 05, 2013 | Televison & Video
When we built our home 6 years ago, Airtron installed a Majestic NVBR36RN vented fireplace system. We had to turn our gas off a while back and never thought about the fireplace until now when we wanted to...
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Dec 02, 2010 | Heating & Cooling
Vent-Free Gas Fireplace Turns Off
check pilot light to make sure properly in place with thermocouple check gas feed for proper pressure and new doesnt mean free from defects -bad valve,thermocouple,temp sensor
Mar 04, 2010 | Heating & Cooling
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
How do you adjust the piliot flame and where is it?It is a intertherm BDM35 ventless fireplace
its already adjusted. I suggest you don't play with gas. If your having a problem call the gas company.
Oct 04, 2009 | Kitchen Appliances - Others
INSTRUCTION MANUAL /INTERTHERM FURNUES
usually a power surge will fry the transformer unless sometimes if your lucky the manuf. installed a fuse either in line or on the circuit board. 5 amp or 3 amp....any thing bigger wont protect your equipment.
Jan 09, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm Fireplace - Model BM36HCD
Am Looking For same pipe for my fireplace
Apr 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
342 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
