Question about Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
Breather Valve - Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi
  • Porter Cable Master
  • 885 Answers
The Porter Cable FR350A has a head valve (PN A08650) and a trigger valve (PN A08368) but no part called a breather valve. What is your question?
Posted on Jan 18, 2013
Where is a pcv valve for a 2kd Toyota diesel engine located?
A PCC valve usually pushes in to the rocker cover with a breather pipe attached to it there is not usually wires connected to it as it's just a breather like valve
Jul 07, 2016 | Toyota Cars & Trucks
Valve breather shots out oil when engine is running
I do not think this is a gasket issue, if the machine has beed tipped up oil will travel up the breather tube and enter the air filter case, over filling will also cause this, if its been tipped it will clear if you run it for a time with the filter off.
Jul 03, 2012 | Toro Lawn Mower With Toro Power Tools
94 buick lesabre .sounds like it is sucking a lot of air thru the breather.
replace your PCV (positive check valve), this is the thick tube located at your valve cover
May 18, 2012 | 1994 Buick LeSabre
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
Runs good but oil is running out of carb
I would start by removing the valve breather, it is held on by 2 screws, and cleaning it with parts cleaner, blowing it out with compressed air and let it dry.
With the breather removed, you can spray parts cleaner through the long tube running from the valve breather to the carburetor.
You may also need to drain the carburetor bowl by removing the carburetor bowl nut located on the bottom of the carburetor.
If that does not help.The next step would be,Your breater or (PCV) valve is gone. Follow the hose from the carb breather to the crank case breather. There are two screws that holds it into the valve case. Remove and replace it along witht the gasket
May 15, 2011 | Mantis 4-Cycle Tiller
Donde queda el pcv valvula en el motor
The PCV valve on Altimas looks different than what has been common for years on most engines. The PCV valve is located at the drive belt side of the engine under the intake manifold and attached to the breather/separator. Access from above is very difficult; access the valve from underneath the vehicle. There is a short hose that connects to the breather/separator.
Remove the breather/separator and the hose. Then you can unscrew the PCV valve from the breather/separator for easy inspection and cleaning of each piece. Also inspect both passages where the separator and hose connect. Here is a picture of the valve after it is removed. The breather/separator is a small aluminum housing that will fit in your hand.
http://www.rockauto.com/catalog/moreinfo.php?pk=56137
Obviously the PCV system is more difficult to service on Altima engines than the more familiar design on so many other engines. A restriction in the PCV system will increase crankcase pressure. This pressure inside your engine will push oil out where ever it can find a place to leak, including into the distributor.
Hope helps.
May 06, 2011 | 2000 Nissan Altima
Where is the breather filter on a 1994 ford taurus?
If you mean the crankcase breather filter, I've looked into this, but I haven't found any reference to this existing on a 1994 Taurus (at least with a with a 3.8L engine), except for some online parts companies that list it for the 1994, but either they're wrong, or if there were 1994 Tauruses that have a breather filter, I suspect it's for an engine other than the 3.8L. It's used on earlier Taurus models, but only up to 1991. Some people say the PCV valve performs the function of the earlier breather filter, but I don't see how, since the PCV valve just opens and closes, and does no filtering once it's open. On one web page where breather filters are discussed (http://www.taurusclub.com/forum/82-maintenance-repair/79542-bad-pcv-valve.html), it's said that adding one to an engine that didn't come with one, doesn't help increase horsepower or mileage, and can bring in air that's not metered by the MAF, which can actually reduce horsepower and mileage.
Oct 20, 2009 | 1993 Ford Taurus
Kolher 17hp motor blowing oil/gas mix out of breather tube
I had the same problem! I found that the needle valve in the carb was not shutting off the fuel flow when not running. Either replace needle valve or put a shut off valve in the fule line. Should take care of the problem
Apr 03, 2009 | Craftsman Garden
1000s breather
by the frame but from looking at old posts it seems it should be mounted into the spigot on the engine casing? Also my bike has K&N's so obviuosly the old airfilter box has been removed. Thus the vent to atmoshere which used to run through this box now simply runs down to the back of the engine. ... so my 2nd question is this... should this vent to atmosphere have a valve on it? ,The breather system should have one valve in it and it should be AFTER the breather box on the line that vents to atmosphere. THis is to stop wet cold air entering the breather box and mixing with hot oily air and making mayonaise or aioli. Guzzi's earlier attempts put two valves between the breather box and crankcase - stupid. If you're bike has the old breather box and not the breather box in the frame like the later square fins then remove them - one is hidden in the supply pipe in the breather box - remove with hammer and screwdriver. This will also stop the engine pumping oil up the return line and out of the engine. Any 4 cylinder automotive spring loaded PCV valve will do pretty well. You can improve the efficiency of the breather box by lightly stuffing it with stainless steel wool or such. If the rings are good and the sump level is right it will not drip oil IME.,,,
Nov 10, 2008 | 1992 Moto Guzzi Quota 1000
Porter Cable FR350A Factory Reconditioned 3 1/2" Round Head Framing Nailer Kit, 70 120 Psi Logo
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
