Question about Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater...
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to ignite. It's less than a year old.
  • 2 more comments
  • adsmclayton Jan 25, 2009
    I TO HAVE A BOSCH 1600 H N. G. WATER HEATER. THE PILOT LIGHT
    WILL LIGHT BUT THE MAIN BURNER WILL NOT IGNITE EVERY TIME.THIS HAPPENS A LOT ESPECIALLY AFTER THE HEATER HAS BEEN USED RECENTLY AFTER IT HAS BEEN HEATED UP IT WILL NOT IGNITE THE MAIN BURNER.
  • George Gouw
    George Gouw Jan 27, 2009
    Bosch Aquastar 1600H .
    Yes, I have the same problem since a few month ago, especially after using it continuestly for 1/2 hr .
    I just both and install it on May 2008. Try to clean all the water flow , but not much help.
    Where is Bosch Tech.Support ???
  • Anonymous Mar 29, 2009
    This is Sunday Moning and we are getting ready for church. NO HOT WATER. We do have clicking, we have gas and we have water flow.
    This is the first time we have had trouble with this unit. Would like an answer. Please contact me at 843-813-9676.
    Cold shower - Larry
  • George Gouw
    George Gouw Apr 01, 2009
    How do you let Bosch honor the warranty for a unit less than a year old ? The service tech. is not even a technician.
The clicking is a good sign. What are you trying that not working? How is the water flow-is it strong? 1) Turn the flow control button all the way to your left - this will increase the flow.
2) Pull the relief valve to simulate water flow and listen for clicking sound, and hopefully, main burner ignition. ( if installed in basement or kindly use bucket to catch water) The 1600 H NG will automatically shut off firing after 5sec of clicking.
3) How is the venting-use a household digital carbon monoxoide detector to measure any backspill from chimney.
4) Was the gas line disconnected in anyway after heater was installed? Air in the gas line will cause the igniter to click but no gas to fired the main burner.
Todate i have installed 11 Bosch Tankless Heaters -- 9(125 NG) Which is the same as 1600 Series
1(1600H NG) and 1(1600P NG)
Guess which one I having problem with- You guess it, however, the problem is their electrical wiring.
BE CAREFUL IN CALLNG BOSCH TECH. FOR SUPPORT. THE ARE GRILLING YOU TO FIND A LOOPHOLE WITH YOUR INSTALLATION TO RELIEF THEMSELF OF THEIR WARRANTY.
Posted on Mar 24, 2009
  • gpl2
    gpl2 Mar 12, 2014
    That they did. I was able to fix the problem by bending the spring upwards just a little bit to that spark was more in the path of the gas. That seems to have worked.
    New Friend:
We looked into this problem ourselves... On our unit there is no wind or drafting problem that could blow out the pilot but still it would often lite and then go out or not light at all (just clicking from the ignitor sparking). I removed the right angled elbow tubing which channels the gas for the pilot from the pilot valve to the ignitor. then manually lit it at the valve (WATCH OUT THIS CAN LEAD TO EXPLOSION) DO not do this unless you are qualified) WE got our hair singed when the main valve opened and the burners lit from that distance..! poof! WOW that was exciting.... anyway we found that if we lit the pilot at the valve, though it fluctuated, it stayed lit... So why would it stay lit at the valve and not at the other end of the elbow which directed it to the igniotor spark and teh burners? It appeared to me that the little "spring" looking receiver which is the destination of the ignitor spark was too close to the exit tubing and did not have enough oxygen in order to light consistently. This seemed to be confirmed by more consistent lighting of the pilot if I blew gently in that direction while it was trying to light. The Solution I have use and is working so far is to streche the little spring out and upward so as to light the pilot a little further away from the exit of that tubing and so far it is lighting every time! At least with the entire front panel/cover ( the large white three sided one with all the controls knobs etc. in it) removed. I hope it works when I replace that...
Posted on Dec 09, 2010
  • 1 more comment
  • GlenBurton Dec 09, 2010
    sorry about the spelling!
    If you have questions you can email me at dirp1@earthlink.net
  • gpl2
    gpl2 Mar 12, 2014
    Is your unit LP or NG? I think moving the spring up helped the most as it put the spark more into the gas as NG rises. These units probably work great with LP.
  • 34 Answers
It sounds like the thermal coupling ( sorry if its spelled wrong) it will be under warranty call them. Bosch heater have a lot of probs...thats great for me the plumber but bad for yall. They sould cover it under the warranty.
Phone Support:
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
Posted on Feb 04, 2009
    New Friend:
Check the silver wire that comes out of the electric control box and goes to the spark ignitor...if that wire is touching the gas valve housing anywhere it may be grounding out or something. We just moved the wire so it wasn't touching any metal and it worked like a charm.
Posted on May 27, 2010
  • William Sumahit Mar 03, 2011
    Thanks for the post. When I first read it, I thought it would be most remote of our situation.We've had a problem with a big Boom when it finally lit. I found a break in the silver igniter wire insulation. So, I wrapped it with black electric tape. I turned off the gas and opened a hot water faucet. I noticed a spark jumping out of the end of the electric tape. Evidently, this spark was what ingited the gas. Only after it traveled to this ignition point - resulting in the Big Boom.
    Taping it wasn't enough to contain the spark, so I slid a 'drinking straw' over the silver wire. It works - just a little poof when it lights. Thanks for shortening my day. Target181
  • don  hopkins
    don hopkins Aug 12, 2011
    I've had my Bosch 1600 ng for about 2 years now & absolutely love it! Twice now it has had problems lighting/igniting. I checked voltage, even though only 1.0 vdc, after adjusting the spring has fixed my problem . Don't know why it would need adjusted or quits, but all I do is blow out the little 90degree pipe with the spring, push spring in with phillips head screwdriver & we're in bizness again! the energy this unit saved me over my old electric water heater is amazing!!
    Problem Solver:
  • 14 Answers
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. We cleaned ours to no avail. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum. I just checked mine, and it was under .85 volts DC. According to the manual that means the electronic control box is defective.
Thanks,
Mike Wenger
  • Mike Wenger Apr 07, 2009
    Be sure to check to make certain you do not have TOO MUCH DRAFT. Disconnect one of the flue pipes in the area of your Bosch tanklesss and hold a flat sheet of paper near the flue pipe. If it sucks up and holds to a cold flue you may have so much draft that the tiny amount of gas required for the pilot is simply dissipating up the flue before it can light. I changed my venting to break that suction (I only need this on windy days), and now my 1600H lights every time.
  • papa9126 Nov 15, 2010
    we are having the same problem. it worked fine for the first 3 to 4 months. then there came some strong wind. now we are lucky if it lights half the trime. I had mine installed by a professional plumber because i dont know much about it, but they don't seem to know much more about them than i do. all i can say for sure is that the copper connections don't leak. by the time installation is added in, we paid about twice what the standard water heater costs. my wife is not happy.
    New Friend:
TEMPORARY FIX FOR HOT SHOWER NOW, light @ ignitor with a lighter with metal tube, not a match. I have had a Bosch 1600 ng for about two years now & we absolutely love it! However we have had problems with the unit not lighting twice. The voltage checked out to be a little low (@ 1.0vdc) but still sparking fine, this is the clicking sound. To fix I pull off the little tube with two screws, be careful not to loose screen between gas nozzle & tube, blow out & adjust spring in end of tube closest to ignitor. I use a phillips screwdriver to push in, just move it to adjust and it should light every time. :)
Bosch tankless GWH 1600 H NG won't always ignite - 203b953b-7f05-4654-bbb4-51ac818e9fed.jpg
Posted on Aug 13, 2011
  • 1 more comment
  • Tom Kenny Apr 04, 2013
    Any chance you're still around this thread? Can you describe the 'little tube' some more? or take a photo of it?
  • don  hopkins
    don hopkins Dec 03, 2014
    Hello Tom Sorry I haven't been around for awhile, I didn't realize I had a question till today. I'll add a couple pictures of the tube shield I remove & the tube I clean.
  • don  hopkins
    The picture on the bottom shows the shield , two screws I remove which holds the metal tube 90 deg elbow with spring in end and screen at bottom.
    New Friend:
I spoke with Bosch. They said I had a bad microswitch. They instructed me to disconnect the wire going to the microswitch and then short out the end going to the ignitor with a paper clip or screwdriver while the hot water was running. As soon as I did this the water heater sparked up and hot water started running. They told me the microswitch was an "un-necessary" backup switch.
Posted on Mar 06, 2014
  • Anonymous Jan 25, 2016
    I had this same problem about 5 years ago and they instructed me to use the paperclip too. Worked like a champ until I got the new part for the fix. Fast forward 5 years, and I am once again having the same problem, only this time they won't tell me how to do the paperclip trick and I can't remember! Do you recall how to do the paperclip bypass? Any details much appreciated to get me through until the new part comes. (This time I'll take a picture!)
Check the voltage on the Orange Wire on the right side of the unit...it should be around 1.3VDC while sparking. If not then just like wengerplumb said, defective box.
While sparking does the pilot light with a bbq lighter? If so try manually bending the pigtail at the tip of the pilot tube to direct the flow of gas towards the spark.
Posted on May 06, 2009
2 Suggested Answers
SOURCE:
SOURCE: roblem with the Bosch 1600H-NG
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
I have a Bosch gas tankless water heater, model GWH 425 EF. The igniter does not stop sparking once the flame is lit. What will cause this?
Your electronic ignition unit is not rectifying through the gas flame, it is a sensitive piece of equipment and has failed.
Jun 08, 2015 | Bosch Water Heaters
On my gwh 1600 h ng the igniter won't spark.
The igniter may not be receiving the call for heat, im not familiar with these setups, but if there is sensor or a heating element they could have gone bad.
Sep 08, 2014 | Water Heaters
No spark Bosch tankless GWH 1600 H NG
On a 1600H for god sakes give the Tech the S/N and the color code on the wiring at the flow sensor that starts the hydro sparker. They changed the thing in Mfr and there are 2 different parts. And also rebuild the water valve occasionally like every 3 years as Bosch recommends even if the cover which guides the pushrod is expensive. FYI we now usually buy a new WV as it\'s more reliable than rebuilding and you get all new parts. It\'s like $125 for a WV vs $59-71 for just the WV cover. Also never run these on very hard water fro a long time or you\'ll never descale em without Whitlam and a long wash out.
Oct 14, 2012 | Bosch 1600H-NG Natural Gas AquaStar...
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 14, 2011 | Bosch AquaStar 2400ES-NG
I have a Bosch Model GWH 1600 H tankless water heater. I have had issues with it since I installed it 2 years ago or should say had it installed.Yesterday I could not get it to ignite or light manually. I...
Igniter can be ordered, but that may or may not be the issue.
Your tankless unit -and- plumbing system need total check-up by trained service technician.
Open following links for Bosch troubleshooting resources including contact Bosch, manuals, error codes, water flow etc.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Check electrical outlet with circuit analyzer to make sure polarity is correct.
Typically, gas water heaters, and especially tankless water heaters require yearly maintenance by service technician who can check the gas pressure and supply, venting, electrical connections, PC board, sensors, burner orifices and igniter parts are clean and positioned correctly, vent is draining correctly and not dripping back into combustion chamber, correct temperature is achievable, incoming water temperature is not too cold for temp setting, proper incoming air supply, adequate air supply, no chemicals stored in air supply pathway, filters are clean, plumbing check valves, mixing valves, pressure valves etc are permitting one-way flow of hot water, water is softened to less than 11 grains hardness, water is filtered and not dirty, aerators and other faucet parts are clean and support water flow necessary to activate burner.
Jul 15, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
BOSCH error codes:
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Just installed a 425 hn, the igniter clicks and the pilotflame goes on and off at the same rate as the igniter clicking. The main burners will not kick on. Checked all the electrical connections, checked...
I am not aquainted with the Bosch..... But it is a heater. I am going from past experience with gas furnaces and how the process works..... You said that you can get the pilot to stay on if you unhook the Main Gas Valve wire. Do you have 24 Volt power on that wire to Common? Does this have a Flame Sensor? Maybe it got damaged. Does it have a good ground from the burner to the ignition control module? Does that wire to the electro valve go into a plug that plugs into the ignition control.... Maybe that pin is not making contact to the board. Hope this helps If no one else answer right away repost Or call and see if you can get Tech support from Bosch..... I know how frustrating it is you buy something brand new and it doesn't work
Feb 01, 2011 | Bosch 425HN NG Tankless Water Heater
We hzve natural gas ion oujr cabin but no electricity. Does Bosch 1000P NG require electricity? My plumber says electricithy is required. I need a DEFINITIVE answer. Thanks
LOOK AT THE UNIT WHERE THE GAS GOES INTO THE UNIT IF YOU SEE SOME KIND OF A SPARK PLUG WIRE YES YOU WILL NEED ELECTRIC FOR THE UNIT TO FIRE, MOST OF THE UNITS HAVE WHAT THEY CALL A STANDING PILOT LIGHT WHICH STAYS LIT TO IGNITE THE GAS WHEN NEEDED. LOOK AT THE UNIT FOR INFO FOR VOLTAGE THERE HAS TO BE SOME KIND OF TAG FOR THIS TO COMPLIANT FOR SALE OF THE UNIT
Sep 23, 2009 | Bosch 1000P NG AquaStar 2.6 GPM Indoor...
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Logo
11,051 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
