Question about GE Energy Star WCVH6260F Front Load Washer
No display when power on pushed
Door locked light comes on but nothing else lights and no buttons work. pump motor started once when pushing buttons and had to unplug to stop but normally is dead except for door locked light.
  • Anonymous Dec 02, 2007
    only the door lock light comes on but nothing else works what is the problem?
Had the same problem as described above. Could hear it trying to pump out the water but had no lights except for the Door Locked light. Cleaned the pump filter by removing the bottom front cover. Unscrew the filter and clean out the lint and junk. Have a bucket ready to catch the water.
Posted on Dec 03, 2007
I FINALLY RESOLVED THE PROBLEM ONLY BY DISCONNECTING AND RECONNECTING ALMOST ALL CONNECTIONS IN THE WIRING HARNESS.  REPLACING DOOR LOCK SWITCH AND MAIN BOARD WAS NO HELP.
Posted on Oct 20, 2007
What kind of board???
Posted on Oct 13, 2007
  • GE Master
  • 909 Answers
NEEDS NEW BOARD
Posted on Jul 19, 2007
SOURCE:
I have a Amana Mod:NRW4600YQ1 FIRST JUST THE RED LID LOCK LIGHT WAS DISPLAYED. NOW IT WONT DO ANYTHING. I DID THE RESET THING AND THE GREEN POWER LIGHT CAME ON ONCE AND NEVER AGAIN Nothing works.
These washers are a little complicated and I also have to perform the service test to see which direction to go in. You said you did the reset thing, not sure what that is but try unplugging washer, walking away and do something, then come back. This is to make sure there is enough time to cut power off inside control board. Next, look at start button, it should be rubber, and make sure it's not pushed in and out of position. I've had a unit with a pushed in start button and it causes problems with start button. Good Luck
May 25, 2016 | Amana Washing Machines
My dishwasher won't start when i push the button, why ?
call a repairman .most likely the door lock switch has failed onit .
Sep 24, 2015 | Dishwashers
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Aug 13, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oven Door Lock Stuck Out
We had this same problem. We found that pushing the censor button/switch on the upper left rim of the oven's inside moved the lock and made it capable to unlock, or purchase a pizza pizzaz.
Oct 05, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
GE Energy Star WCVH6260F Front Load Washer Logo
209 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
