Question about Technics Audio Players & Recorders
No sound from left channel on my Technics SA-R 230
No sound from left channel on my Technics SA-R230 Receiver no matter what source of input is selected. Would like to know what internal part / parts need to be replaced in order to repair.
    Genius:
  • Technics Master
  • 1,054 Answers
May just be bad connections on the speaker relay. Flip the main board over, and check those connections. It is pretty common on these older models.
Posted on Jan 18, 2013
  • 125 Answers
SOURCE: Noisy channel of receiver
Generally, crackling noises come from anyplace there is a mechancial connection for the sound signal. The volume control, main/remote speaker switch and possibly the headphone jack. That is where the contacts must be cleaned, but it requires dissassembly. Try operating the main/remote speaker switches, and plug/unplug a headphone several times. I am assuming there is still audio behind that crackling. Are you using both main and remote speakers simultaneously?
Posted on Apr 09, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
  • 21 Answers
SOURCE: A and B channels both have left speakers out.
Use a multitester to check the amps then you can find which amp it is.Under the cover youll see two boards on a aluinum plate.
Posted on Oct 27, 2009
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
Can i hookup a television to my receiver for sound
Yes. You can hook it up using a digital coax or optical cable. Use can also use old stereo, analog, left and right channel audio. Use any audio input on your Technics, that will accept any of the inputs above.
Feb 09, 2015 | Technics SA-DX940
No sound
the service manual http://www.hifiengine.com/hfe_downloads/index.php?technics/technics_sa-500_service.pdf
Jul 27, 2014 | Technics SA-EX500 Receiver
Trying to hook up SH-AC500D to SA-AX720 Receiver. I wanna know the right wires to use. Thank you
Connect the 6-channel analog outputs of the AC500 to the 6-channel analog inputs on the AX720 using 3 RCA cable pairs.
http://archiwumallegro.pl/technics_shac500d_procesor_surround_ddigital_dts-1215399983.html
Digital sources will enter the AC500 and be converted to 5.1 analog output.
Be advised, that input on the receiver will not allow any internal DSP manipulation. WYSIWYG.
Feb 04, 2011 | Technics SA-AX720 Receiver
I have a Technics Stereo Receiver SA-GX 500. There is very little sound coming out of all the speakers (A and B) as well as the headphone jack. I have made sure that the speaker button is depressed (A, B...
All sources or just one? Make sure the Tape Monitor isn't engaged unless you're using an external tape deck or processor. A turntable will only work on the PHONO input.
Aug 08, 2010 | Technics SUV500 2-Channel Amplifier
Technics SA-DX940 Digital optical audio input
When you say you have sound from the BD prior to disc load... where (TV and/or receiver)? Initial wake-up audio is usually 2-channel.
Describe the optical audio connection input to the receiver and any other audio paths that are attached.
Do you have other multichannel sources you could use to test this, like a cable TV box?
There's an obscure setting in the receiver called PCM Fix (on Page 21). Give that a look.
Jun 07, 2010 | Technics SA-DX940
Oct 26, 2009 | Technics SA-EX140 Receiver
No left channel sound
check wiring. if ok, swap speaker channels if ok, swap rca plugs, if ok. Bad channel on amp.
Jun 29, 2009 | Technics SA-DA10N 5.1 Channels Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
250 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
