Question about HP Pavilion dv1000 Notebook
In the boot sequence it says SMART failure.......... backup ur HDD it may crash anytime.............. press F1 to continue........ but in the bios option hdd compability test result shows hdd is ok.... pls give me reply
    President:
  • 2,992 Answers
The compatibilty test doesn't check the drive operating parameters that SMART monitoring does. It's just verifying that the drive will work with the BIOS. SMART checks various drive paramaters while the drive is in use and warns you when something is enough out of tolerance that it may be heading for a failure. Best you back up your data like it says. Even if it's a false alarm, backing up is a good idea anyway.
Posted on Jan 25, 2009
SMART Failure Predicted on Hard Disk 0: ***************** Warning: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to continue
this is the indication that your hard drive is failing in self monitoring and reporting tool which is done by the bios , in the initial booting time, its better you should replace the hard disk by backing up your data as soon as possible or if you don't want to see this message simple go on to your bios then disable smart option of the hard drvie
Feb 12, 2013 | Samsung HM500JI 500 GB SATA Hard Drive
Smart failure occured in harddisk
Get to a command prompt during boot by pressing F8 and run chkdsk x: /f/r X being most likely the C drive that has the SMART predictive drive failure, or disable the option in BIOS.
Nov 29, 2012 | Computers & Internet
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
Smart failure predicted on hard disk 4 toshiba MK1032GSX-(S1) press F1 to continue
You may continue on and boot the system.
However it is time to backup the data on that drive and replace it.
the S.M.A.R.T system is a warning.
Sep 07, 2011 | Toshiba Computers & Internet
My laptop is saying that their is no operating system not found what do i do to fix this problem i have a sylvania 8.9 lcd m 512mb and a 160gb hdd
check the bios whether the HDD is dectected (you can the get the bios by tapping F1 in XP and F10-in Vista and windows 7) if the hdd is dectected perform a smart short test (click on ur harddrive-smart support-smart short test )-----If the harddrive passes the test
-then try hitting ESC while boot up select the hdd to boot check if that works
if that doesnt work then you need to run the the operating system disc
Apr 25, 2011 | Intel Computers & Internet
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
Everytime my laptop opens its saying a SMART failure was detected in ur hard disk drive,click F1 to continue...do i really have to change my hdd or it can be fix..but if i check in device manager it says...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive or
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
good luck with this
Sep 15, 2010 | Hitachi Computers & Internet
Acer Aspire 5100: SMART Failure on Hard Disk 4
Hello there,
As per experience, SMART Utility will check your HDD for any errors that may occur.
I backed up everything and replaced a new HDD and got rid of the error.
Opened up the problematic HDD and noticed a very light scratch on its "platters".
As for me. Never ignore this warning before something might happen to your HDD and lost important data.
Mar 08, 2010 | Acer Aspire 5100 Notebook
HDD SMART Problame
SMART [Self Monitoring, Analasys, and Reporting Technology] is on the actual hard drive and its telling your bios its on its way out
Basically, even if comp tests pass, if theres anything important on it or its an important pc change the hard drive asap...
let me know... Matt
Jan 25, 2009 | HP Pavilion dv1000 Notebook
Hard drive controller
These can be fun and Hdd/IDE/SATA Controllers on Desktops are different than laptops.. Embedded controller chips as well as the Northbridge/Southbridge chips are integrated to everything else and its a nightmare to track down period. (Ive had to replace Integrated Modem chips to cure a Boot or BSOD error that states the Video Adapter needs to be changed) ..(Generally due to Power surge or other).. You are on the right track however and I'd just suggest running Memtest of the Knoppix to start be4 I can say other. Is there Shared or dedicated RAM for the GPU on this one? They manned both ways depending on the specific board revision..
Talk soon, Ken
www.ikenfixit.com
Nov 10, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
