Switches itself off intermittently Dimplex Danville optimyst
2 Suggested Answers
  • 3698 Answers
SOURCE: fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Posted on Jun 30, 2014
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Jun 29, 2014 | Heating & Cooling
Dimplex electralog is making an intermittent squeaking sound?
When it is switched off try spraying WD40 around end of spindles. Try heater again after about an hour.
Nov 30, 2013 | Dimplex Compact Electric Flame Stove...
When i changed the bulbson my dimplex optimyst charlotte crt 20 br with origianal bulbs from dimplexthey dont work yet the power supply isworking
I had the same problem. It turned out to be the lamp holders themselves which were the problem. Just take out the single screw just in front of the lamp holder assembly and the lamp holder unit comes out. Remove the main lamp holder assembly and turn it over. You will see the four lamp holder wires all go to two main terminals with a positive and negative connector on each. You need to undo the nuts holding the main supply cables and lamp holder wires and remove the cables noting where they came from for easy replacement. If you cut off the wire on the defective units and unscrew the two retaining screws holding each lamp holder they can be removed. You can order on line replacement holders from Amazon and with a little bit of simple soldering and using new wire connectors for the end connectors on the new lamp holder wires can be easily fitted. I have two of these fires and both have had the same fault after about 12 months use, obviously a fault with the holders as they dont last that long and need replaced.
Apr 05, 2012 | Heating & Cooling
Bulb blew in my dimplex michigan fire, model MCN20. I now can't get the bulbs to switch off with either the remote control or the on/off switch.
Stewart, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and wait 12 - 15 minutes. Then plug the unit back in and turn the Master ON/OFF Switch to ON and set the function controls manually (not with the remote) one at a time. If everything works as it should, the fire reset itself during the 12 - 15 minute timeout. If it didn't or that problem continues to reoccur, contact Dimplex North America, Technical Service at 888-346-7539.
Hope this helped you solve the problem.
Apr 27, 2011 | Heating & Cooling
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
My customer just bought a CS 1205 from our True Value Store. The blower on the new CS 1205 does not work. It has been used three or four time. The flame comes on however. What do you suggest?
Before call Dimplex Technical Service (888-346-7539) have your customer turn the Master ON/OFF Switch to OFF. Unplug the fireplace for 12 - 15 minutes. Once plugged back in, have them turn the Master ON/OFF Switch to On and then turn ON each function of the fireplace one at a time. If everything is performing as it should, the unit reset itself. However, if this becomes a recurring problem, they should contact Dimplex Technical Service.
Hope this helps you solve the problem for them.
Apr 05, 2011 | Dimplex CS1205 Electric Compact Heater
Just purchased a dimplex DS5629 electric stove. Plugged it in, but NO HEAT and NO BLOWER. Dimplex is closed for the weekend. NOW WHAT???
Ar e you sure that the receptacle your have it plugged into is working? If it is, you can try this. It usually works. Turn the Master On/Off Switch to OFF. Unplug the unit and leave unplugged to 12 - 15 minutes. Plug the unit back in and turn the Master On/Off Switch to ON. Then, turn each individual function one at a time. If they ail function as they should, the unit has reset itself.
If it doesn't work, then you'll have to wait until Monday to contact Dimplex OR you could contact the retailer you purchased it from and have them replace it immediately. That is, unless you purchased it online. Then, it would be better to wait until Monday and contact Dimplex. Be sure you have your Model Number and Proof of Purchase, when you contact them. In case you don't have it, their Technical Support number is 888-346-7539.
Hope this helps you solve the problem.
Apr 01, 2011 | Dimplex DS5629 Electric Heater
I have a Dimplex model D55804C SN 19005D4F579. the lower bulbs behind the flames do not light up. I changed the bulbs thinking that was the problem, but still no light. Can you tell me what I need to...
Maryanne, the first thing to try is turning the Master ON/OFF switch to OFF. Unplug the unit and allow it to remain unplugged for 10 - 12 minutes. Generally, that's enough time for the unit to reset itself. Plug the unit back in and turn on the Mater On/OFF switch and then proceed as you normally do.
If that solves the problem great! If it becomes a recurring problem, turn the fireplace off, unplug it and call Dimplex USA Technical Service 888-346-7539.
Hope this helps to solve your problem. Please let me know.
Mar 15, 2011 | Dimplex Heating & Cooling
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
