Jaguer 2.0d . the boot will not close at all. all other locks on car are working ok. i took the boot lid lock off and disconnected wires.then i noticed that the motorised leaver had the lock in the open position so then i removed the motorisid leaver[2 torq screws]and then the lock worked ok. the motor has the lock stuck in the open position . i get the feeling that there is no power to motorised leaver but the alarm side to the boot works. is there a fuse that would do this as i think every thing els works .
I have a 02 x type jag. the dash is telling me the boot is open even though its not, because of this this the central locking or alarm wont work and the interior light is on permanently ??
Hi, I've got the same problem with my 54 plate X type 2.0 diesel, what I've done was removed the lever from the mounting frame then tap and lubricate the lever using grease spray then pressed the remote boot release button, the lever worked back after awhile. but do you think this is a concern issue that needs to be relayed to the Jag Dealers for recall of this type of lever model by trhe way the lever was produced by Ford.
i have already tried pressing the button with the lock in my hand and all wires connected and still nothing. i have also tried the same with the key then going back to the button . could it be a fuse? thanks wend
i solved this problem . the problem is that the motorised leaver is sticking. remove the plastic cowl by first removing screw like clips then remove 3 torq screws which hold the lock in place .unplug wires. once the lock is removed you will see that the motorised leaver has the lock stuck in the open position. remove the motorised leaver by removing 2 torq screws. next you will need to send 12volts though the motorised leaver motor . just touch the wires on to the to terminals first one way then revers the wires which will send the motor the other way at the same time tap the the motor and it should releas the motorised leaver. you may have to try a number of times . oil and replace
thanks a lot wendy_slee! saved me ~3-4 hours and $200. '04 X-Type Europen version (leaver made in Portugal)
Ok wendy hold the latch in your hand connecteded up and shut the other doors press the button, an will the latch lock and unlock try this a few times wendy this is differant in other countrys as america has a different latch D
is there a leaver inside the car to open the boot
