Question about Omega Juicers Juicer 1000 Brand: Omega
Right Arm of Omega Juicer Model 1000 broke off
Cleaning person in my house broke it 3 years ago - thought they repaired it with the manufacturer - but I notice that they just glued it. What should I do to repair the arm/clamp? The juicer won't work unless it is closed properly.
    New Friend:
You have to unscrew the screws and use a wrench to undo the bolt. Then take it apart then you will see the latch arm attachment. push the top outward and then push it up then It will come out.
Posted on Aug 11, 2014
    Champion:
  • 356 Answers
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Posted on Jun 30, 2009
Why does juicer not start when assembled and plugged in?
It has a 10 year warranty, but check the instructions as there are bound to be safety features on it to stop it working unless properly locked together.
Omega BMJ330 Commercial 350 Watt Stainless Steel Pulp Ejection Juicer...
Review
Omega BMJ330 Review JuicerReviewsDirect com
Manual is here. Doesn't look as if there are any safety interlocks in the drawings. Aha, there is a safety lock! It is good to read to the end :>) Page 23 states;
IF YOUR JUICER ISN'T WORKING
If the latch arm on the right side is not secure and properly in place the juicer's safety switch will not engage. Therefore, the juicer will not work. Assemble the juicer properly.
https://www.omegajuicers.com/media/manuals/EFS_BMJ330_390_Manual_JUNE2014_web.pdf
Aug 22, 2014 | Omega Juicers BMJ330
I have a 15 year old Omega 1000 that needs an arm replacement. Is it possible?
LOOK AT ALL THE OTHER JUICER`s they are not made that difffernt just put another drive on it and run the one that fits it !?
Aug 30, 2011 | Omega 1000 Juice Extractor
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Jan 30, 2011 | Omega 1000 Juice Extractor
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
Nov 22, 2010 | Omega 1000 Juice Extractor
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
Aug 26, 2010 | Omega 1000 Juice Extractor
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
Jun 29, 2010 | Omega 1000 Juice Extractor
Need to replace latch arm omega juicer
First thing to do is call Omega and order a pair
at 1 800 633 3461 and also ask them for tips on
how to remove and install the arm. If your juicer
is older the new arms may not be an exact fit, and
you will have to do a little filing and improvising to
install them. Its helpful to remove the 4 screws on
and view of the situation.
May 20, 2010 | Omega 1000 Juice Extractor
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
May 08, 2010 | Omega 1000 Juice Extractor
How do I replace the latch arm?
I WOULD CALL OMEGA AT 717 561 1105. I REPLACED ONE
ON AN OMEGA 1000 BY REMOVING BOTTOM OF JUICER
TO VIEW LATCH ARM WHERE IT ATTACHES FROM INSIDE
THE HOUSING. YOU CAN FIGURE IT OUT. IT HAS TO BE
PRIED A LITTLE AND SLIPPED UP AND OUT.
Oct 19, 2008 | Omega 4000 Juicer
One bracket broke. Tried to glue it with no success.
IF YOU ARE TALKING ABOUT THE LATCH ARM, YOU CAN BUY THEM FROM OMEGA AT
717 561 1105. TRICKY TO REPLACE. I REMOVED THE BOTTOM OF THE MACHINE AND
GAINED ACCESS THAT WAY. ONCE YOU SEE THE LATCH ARM SUPPORT PRY IT AWAY
FROM THE JUICER AND SLIDE IT OUT. CALL OMEGA THERE ARE 2 WAYS TO REPLACE
THE LATCH.
Sep 29, 2008 | Omega 1000 Juice Extractor
Omega Juicers Juicer 1000 Brand: Omega Logo
425 people viewed this question
Top Omega Juicers Experts
eyecam
Andrew Taylor
Andrew Taylor
Are you an Omega Juicer Expert? Answer questions, earn points and help others
