Question about My Weigh Triton T2 - 120g x 0.1g Precision Scale All Black w/ Red Backlit Digital Display Weight Scale
My WeighTriton T2 readout says EEEE then it shuts off
Does that mean its broken or is there a certain trick to resetting the scale. Because even after i calibrate it with a 100g weight, at the end it flashesn CAL then its supposed to read PASS then you remove the weight from the scale cycle it off then back on and your ready to rock. However my scale flashes CAL when finished but then just EEEE and it turns off. Then when i turn them on after shutting off, the readout says out 2
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Jul 16, 2015 | GNC Digital Bathroom Scale
What does it mean when my Boflex body fat scale reads Lo then turns off
My scale readout is now blank? Do I have to buy a new battery?
First, did you notice of the scale had a "lo" or "bat" display before it went blank? If so this means the battery needs to be replaced. If you did not get the battery indicator, did you "miss" seeing this? Has it been a week since you were on the scale? If you stand on the scale regularly and did not receive the battery indicator then you can try the reset procedure above.
Source: <http://www.taylorusa.com/faq-scales> Syz D
Aug 22, 2014 | Health & Beauty
How to remove the tray on a triton t2 300g digital scale
Google a triton t2 300g digital scale manual and follow the directions.
Mar 10, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Digital readout not readable
Try a new one. If it works, the scale is broken.
Jun 30, 2010 | Taylor Precision Products Taylor Precision...
When you step on the scale the readout says "LO". Does this mean low battery, and if so I can't find a battery to replace.
Yes it means battery needs replacing. Check oringinal papers that came with scale to see if you need to order special battery. Otherwise go to a battery store that recharges batterys. They usually carry most makes. Take your battery with you so you can match right one.
Dec 10, 2009 | Taylor & Digital Scale Lithium Scale
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Mini digital scale displays out2
I just had this problem on set Salter scales (says 3309 on label on back so assume that's model no) which came up OUT2 solidly after hadn't been used for a while.
Looking on WWW this means on other scales they need to be recalibrated. There are only 2 buttons on ths model ON/Zero and 2nd is mode for grams, oz etc. Discovered by trial and error have to hold down the on button and repeatedly click the measure button as it powers up, screen says err2 press on button again and says 5000g, put 5000g weight on scales, press on button again display says CAL press on button and it at first came up with EEEE and failed but next attempt it said PASS and it all worked again. I used 2 x 1.5kg bags flour and 2 x 1Kg bags sugar to make 5kg with bit tipped out of one to make exact and checked on another set scales. So trick appears to be finding how to get your scales in to calibrate mode and what the weight it expects is.
Jun 15, 2009 | Balance Health & Beauty
My Weigh Triton T2 - 120g x 0.1g Precision Scale All Black w/ Red Backlit Digital Display Weight Scale Logo
142 people viewed this question
Top My Weigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a My Weigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
