Question about Whirlpool Ovens
Akz 223 error stop
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Need instrucion manual for whirlpool akz 155
Please check on the link below:
Register your product:
http://www.whirlpool.com/contact-us/
Nov 11, 2011 | Ovens
Whirpool akz 431/01 chyba F 02
Hello & Welcome to FixYa
F2 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Ovens
I'm looking for a manual for a whirlpool oven AKZ 431
try contacting the manufacturer and se if they can supply one also check online to the manufacturer and try to download a printable one
Nov 07, 2010 | Whirlpool AKZ159IX Oven
Akz 451 timer, clock, light and fan all working - oven not warming up - power RCD tripped before fault noticed
I would recommend that you replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Oct 12, 2010 | Whirlpool AKZ159IX Oven
Whirlpool AKZ 446 Electric fan starts but oven does not heat up ?? Is the element easy to replace/fit? Thanks
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
Dec 29, 2009 | Whirlpool AKZ159IX Oven
AKZ 451 will not heat up
element,make sure clock is set though
Jun 29, 2009 | Whirlpool RBS275PD Electric Single Oven
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Ovens Logo
21 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
