Question about HP LaserJet 3055 All-In-One Printer
Pause between printing
The printer pauses between printing pages of a doc
  • HP Master
  • 2,072 Answers
Could be a problem with the formatter. The brain of the printer. You could try doing a factory reset.
Posted on Jan 19, 2013
  • 32 Answers
Perform the following in the order given
(1) Open the printer properties, in ADVANCED tab, select "Start Print Immediately". If not solved then
(2) The paper delivery sensor may be obstructed due to dust. Blow clean the pin holes at both ends (optical path) of the sensor. If needed wipe with a cotton bud. If not solved then
(3) Perform a NVRAM (refer attached page for step by step process)
Posted on May 24, 2014
  • 489 Answers
SOURCE: HOW WILL I UNPAUSED MY PRINTER?
There should be a printer icon in the notification area. You can double-click on that to bring up the printer status. If the icon is not there, you can go to Start -> Control Panel -> Printers and double-click on your printer. The first item in the print queue should be listed as paused. Right-clock on it and select Resume from the context menu.
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: Printer Pauses every few pages, seems to print slower than it shouls
I seriously doubt that this is a network spooler issue but I guess there is a possibility. I was thinking that there is a setting with the paper on the actual printer or something about waiting to start the job until all pages are in memory. I have the problem with a 4300 not a 4100
Posted on Jun 23, 2008
Inkworks
  • 87 Answers
SOURCE: my hp deskjet 5150 will not stop printing
You say test page....what is on this test page? Could be an alignment page.
Inkworks
866-381-0541
Posted on Nov 21, 2008
komguy
  • 2306 Answers
SOURCE: PRINTER IS IN PAUSE MODE.
Pause is set in your computer, you have to go to control panel, printers, and then right click on the printer icon for the printer you are using. Pause is about the third choice down and you need to un-check it and that takes it off of pause.
Posted on Sep 25, 2009
edmacias
  • 70 Answers
SOURCE: Deleting paused and frozen there. Cannot use the
it seems you might need to rest teh PC..
Once you have done that and assuming you are running windows pls do the following (while the printer is OFF)
1. Go to "Start", "Run"
2. Type: CMD
3. press "Enter"
(now you should be in a DOS terminal window)
4. type: net stop spooler
press "enter"
5. type: net start spooler
press "enter"
6. type: exit
press enter
Turn on the printer...you should be clear now :)
Cheers,
Ed
(If this works for you, please grade this response)
Posted on Nov 07, 2009
How to get it off print pause on the printer
If you are given print command and that time printer off position no issue, because print command given after on the printer then printer seance any command or printer print the doc.
Thanks,
Jun 23, 2014 | HP PSC 1210 All-In-One InkJet Printer
Mfc 7340 pause
when we pause some prints from specific computer (if ur using lan) then go to computer where physically printer attached then print some pages and when printer utility display appears on screen find on that pause is enable trying to resume from that
May 04, 2012 | Office Equipment & Supplies
How to printer test page from the display panel zebra zm600
With most Zebra printers, a test page is printed by pressing and holding the PAUSE key while turning on the power. Keep pressing the PAUSE key until the printer completes the POST (power on self-test), then you can let go. A test pattern will begin printing. You can stop the pattern by pressing PAUSE. Turning the printer off & on again is the fastest way to end the test. This is a good page to print because it prints a large black box and it's easy to see if there are any printhead elements not functioning. It's best to use the largest, widest label you have for this test.
Hope that helps !
Aug 29, 2011 | Zebra ZM600 Printer
Hp laserjet p3015 pausing after 5 or so pages whilst printing large amounts, the printer prints 5 pages then has a pause before starting printing again, this can can make printing very slow i've...
I have seen this problem before. Basically what is happening is the fuser is losing it's heat. When the printer pauses it is waiting for the fuser to get back up to temperature. The first course of action would be to reinstall the print drivers. This will rule out the communication aspect. Then to replace the Fusing assembly (fuser) and if that doesn't work to replace the Power supply.
If it is the power supply it wouldn't be worth the time or money to repair the printer based on the original cost of the machine.
Aug 16, 2010 | HP Office Equipment & Supplies
My HP L7580 all in one printer pauses while it is printing any page including the test page from the properties folder for approx. 45 seconds and then continues to print. I've made a photo copy using the...
hmmmm if its just a doc. it not normal...try to make a copy if its doing the same thing-if not them the software driver needs to be reinstall...for further support you can call 1-800-474-6836
Apr 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
PRINTER IS IN PAUSE MODE. I REPLACED AN EMPTY COLOR CARTRIDGE HOPING THAT WOULD FIX THE PROBLEM, BUT IT HASN'T. I CAN RUN A test pattern and printer willprint it out . but if i try to print an email for...
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer pauses after a couple of pages
This is normal, if annoying - it just means that the LED bar is getting too hot and the printer pauses to let it cool down. Really the only solution is to operate the printer in a cooler location.
Jul 04, 2009 | OKI Office Equipment & Supplies
HP K5400 - print pausing
print as image tick it than it will work
Jan 19, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Pause/printer rest between pages
Hi nurse_boop (Lainey), You can try changing some of the printer settings. Assuming you're using Windows, go to Start, Printers and Faxes, and right click on your printer, choose Properties: 1. Make sure that you disable printer pooling; 2. Check/tick, print directly to the printer; 3. Check/tick, Printer is Always Available. Please keep in mind that large file sizes, images and deep colors adds to the slowdown and pauses of printers. Hardware wise, large documents requires more memory both on the printer server PC and the printer itself. Hope this be of some help to you. Post back how things are or should you need further information. Good luck and kind regards.
Aug 24, 2007 | Canon LBP 1120 Laser Printer
HP LaserJet 3055 All-In-One Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
