Question about Sony Xperia U ST25I Android OS v2.3 Cellphone with 3.5-Inch Touchscreen, 5MP Camera, 720p Video Recording, Wi-Fi and A-GPS Support - Unlocked Phone - No Warranty - Black/White
My sonyxperia u has no signal its not the sim
I have no signal tested sim and its not faulty any ideas
    Master:
  • 520 Answers
Hello Dear:::::::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Posted on Jan 18, 2013
Why is the phone not picking up the GSM signal?
Try the SIM on another phone and if the same problem is seen then it can be related to a faulty SIM. Please check the network coverage of the provider in your area. Also counter check the phone with a working SIM to confirm the phone.
Jul 05, 2012 | LG KP500 Cookie KP 500
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Samsung sgh-m200 has no network
No Network error only appear if your phone is not getting the service provider's signal. You need to check the status of your account from your mobile service provider by calling them. You can also check if the sim is properly inserted. You can also check the capability of using compatible sim card to your phone to isolate faulty sim card issues. Try to insert the sim card to another compatible phone as well. if sim card to another compatible phone works then there is a problem from your phone's end by getting a signal.
Dec 08, 2011 | Cell Phones
1994 ford thunderbird flashers work but blinkers do not
There are two possibilities:-- 1) The flasher relay or 2) The turn signal switch.
check flasher relay,but most likely the fault is the turn signal switch . ---------- The turn signal / hazard flasher relay is located behind the dash, right of the steering column. -------- Since the hazards do work this eliminates a faulty relay as both the hazards and turn signals use the same relay to function. This leads to either faulty wiring at the multifunction (turn signal) switch or a faulty switch itself.It is always a good idea to check the wiring before purchasing the switch.Starting at the switch its the lever.And the switch wiring gets connected to relay. Test it with a meter to see if it is getting power when it is supposed to (turned ON ). If it is then wiring is OK and switch is bad. If it's not getting power then there is a open circuit somewhere in between.so its the wiring problem. ------------ this will help.Thanks.Helpmech.
Dec 21, 2010 | Ford Thunderbird Cars & Trucks
Network, Not charging,
It is clear to say that your phone is dead right? Just want to clarify first, did your phone experienced an undesireable thing before it does not recieved anymore signals and dont charge? Okay..Lets presume that it goes that way. So what I want you to do is to make an operation on your phone. Remove the battery and sim. Place other battery into your phone and then connect the charger. If it is charging then this will lead you to an idea of what is really happening of your phone. We might consider the battery is faulty. Place the sim back into your phone, power up. If you see that it is catching signal then your phone now is okay. But if none of this make things right then I suggest that you go to an cellphone repair center so that your phone will be check its hardware system.
Dec 22, 2009 | Nokia 2650 Cellular Phone
Nokia 6500s no signal or service
It can only be three things.
Phone is faulty
Network is not available
SIM card is faulty
Go your phone service provider with another phone and your SIM card and ask them to check it, your SIM Card in that phone using the IMEI number for the borrowed phone. Test it. Ask them to switch the IMEI number back to your phone.
As your phone is 10 years old, I believe it has come to the end of its life. Now you can get a decent phone.
Launch Announced 2007, May. Released 2007, September Status Discontinued
http://www.gsmarena.com/nokia_6500_slide-1996.php
Jul 17, 2017 | Nokia 6500 Slide Cellular Phone
Hi there..i have a signal problem with my nokia 6500
Try checking with your service provider if there's any outage problem in your area. Which is possible since you don't have any bars for signal on your phone.
Sep 05, 2009 | Nokia 6500 Slide Cellular Phone
My voice cannot be heard by other person for brief periods
If the problem repeated when you swapped your SIM card to another phone, it rules out it being a hardware issue. You can take your SIM card to a cellular store and have them replace it. That should fix the issue. I doubt it is the card itself since the card simply holds your account info for accessing the network. It sounds more like an issue within the network where the internal settings associated with your SIM # weren't properly set. Getting a new SIM card will force the system to fully set and associate your account with the SIM and should (fingers crossed) help fix the issue. Good luck!
Aug 31, 2009 | Palm Treo 680 Smartphone
SIM card not valid
Hi thee, I list here the possible reasons for "Sim card not valid"
1 - The phone is locked to a different network. In this case the phone usually accept the sim card the same , and has no network, but sometimes it may return the error message. Unlock the phone at a local shop.
2 - the SIM card is faulty. Test the card on a different phone to find out.
3 - The phone is faulty. Test the phone with different Sim cards, if the Phone returns same error on all cards, then the phone is faulty.
Mar 28, 2009 | Nokia N70 Cellular Phone
Sony Xperia U ST25I Android OS v2.3 Cellphone with 3.5-Inch Touchscreen, 5MP Camera, 720p Video Recording, Wi-Fi and A-GPS Support - Unlocked Phone - No Warranty - Black/White Logo
866 people viewed this question
Top Sony Cell Phones Experts
richie46
Gil Shultz
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
