**NOTE: Remember the position of the old needle when you remove it. If the needle's eye is facing you, the needle's flat side is installed facing the back of the machine. If the needle's eye is facing to the side, then the flat side of the needle faces inward toward the throat of the machine. The instructions below show only the needles where the eye faces forward and the flat side faces backward.
Hoveround manual:
Took the answer right from the manual. If you would like a digital copy of the manual, the link is posted below.
[The swivel seat permits the seat to pivot from the forward facing position through 90 degrees in either the left or right directions. The seat will lock in each of the forward, left and right facing positions. This feature is provided to make side transferring easier. The swivel release lever is mounted on the left side in the standard
position] http://www.hoveround.com/.../MPV4-Power-Chair-Manual.pdf
Make sure your son does not exceed the weight limits for the forward facing harness. Do not put your child in the harness wearing bulky clothing, but use a blanket or poncho in the car instead of a snowsuit or winter coat.
Ensure that piston #1 is at
TDC on the compression stroke. Make sure it is TDC on compression and not on the
exhaust stroke. Once the #1 piston is properly placed then just take the top cap
(camshaft position sensor) off the camshaft synchro. You will see a little half
moon shaped piece of metal in there. Take your alignment tool and slide it onto
the synchro body and the little half moon piece. To get the tool on you will
have to align things a little bit. Just take a good peek at the tool and you
will see which way things will have to go. Once the alignment tool is popped on
then things are properly aligned. Next install the whole unit into the engine.
It will take a try or two but you are looking to get the synchro's positioning
tool arrow as close to forward facing (stock position) as possible. If it is not
forward facing then pull it up and rotate over to the next gear tooth. Keep
trying till you get the proper tooth that allows it to face forward the most. Do
not worry if it is not perfect. As long as the synchro is locked into position
to the body and the piston is aligned properly then your cam timing will read
properly in the PCM. Once you get the synchro in then bolt it down tight. Once
that is done you can remove the alignment tool and install the camshaft position
sensor piece and then you are done.
To install the driver for the Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster please visit this page and download the same for installation.
This will resolve the issue you are facing.
I will look forward to your feedback and positive rating.
u could use the safety straps on the back. or you could run the seatbelt through the holes at the bottom of the car seat. check your users manual from your explorer to see where the safety hooks are.
http://www.eddiebauer.djgusa.com/usa/eng/Instructions?ProductNumber=22790WPR
