Question about Bosch Washing Machines
Remove front panel panel from Bosch wfb1605
How to remove control panel
SOURCE: front panel removal
make and model number would help, post these details and i may be able to help
Posted on Sep 09, 2007
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
SOURCE: Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
Posted on Jun 13, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx - Rubber Door Seal - I heard the
Not recommended, tilt washer backwards, and work spring on with your fingers, slowly going round the inner lip of the seal, it helps if you can get someone to help by holding the spring in place as you work your round the seal.
Please rate my solution.
Thanks.
Posted on Aug 27, 2009
Where is the Bosch dishwasher flood control switch?
Look in the bottom of the unit with the rack out. You are looking for a dome shaped housing. That is the inlet and the flood control. If you remove the kick panel when you locate the dome, you can then look under the unit in that area to see the parts that connect to the device.
Feb 20, 2016 | Bosch Washing Machines
Wfb1605 instruction manual
just visit the bosch website, all manuals are on there.
Jan 10, 2012 | Bosch Washing Machines
How do you remove the front panel where door is located
Welcome to FixYa.
I wouldn't do that...there is nothing or very little which can be serviced from the front. ( aside from the door itself and control panel of course ) all service on the WTMC Bosch is done from the back.
**Unplug the unit from the wall before attempting ANY service...safety first**
i.e.
Remove the top...
Then with the top off, remove the back panel...
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the front of the unit and components, drum rollers, motor, etc.
i.e.
Hope that helps you identify and access what it is you're after for your Bosch WTMC dryer, good luck.
Let me know how you make out or if you have further questions of course, I will help you move further in whatever manner I can.
Good luck.
Regards,
Macmarkus :)
Feb 23, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How do you remove front panel on a Bosch WFO285SGB
This video will show you how to replace the Bosch WFO285SGB washing machine door seal with step by step guide on the process
Aug 13, 2009 | Bosch Washing Machines
How do I replace my boot gasket on my Bosch Nexxt washer?
Here is how you do it. 1st remove the door & hinge, 2nd remove the covers on the screw where the door sits that holds down the control panel. 3rd remove two screws holding the door latch in place. Remove the spring & wire holding the boot on and pull the boot loose from the plastic holder Remove the plastic boot holder. You will now see the boot where it attaches to the tub. There is a spring and wire that holds that on. At the top there is a tab on the seal, grab it and pull towards you. The boot will come off. To reassemble I remove the counter weights(concrete weights) from the tub and put the boot firmly into the slot on the tub. Now reinstall the rear spring. Be sure to also reinstall the counter weights if removed and torque them tight around 25 to 30 foot pounds. Reassemble the front panel and put the spring retainer back on. Tools needed T20 torx driver, 13mm wrench, and needle nose plyers.
Aug 09, 2008 | Bosch Washing Machines
BOSCH WASHING MACHINE RETAINING SPRING FOR FRONT DOOR GASKET
it is very hard to get the ring on front load washers,
it is much easier to remove the top. bottom and the front control panel
then the door and support panel.
now you have access.
some times you have to remove the counter weight in some models before putting on the ring.
if you can do it without removing these items you are very very good.
May 01, 2008 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
