Question about Dishwashers
The dishwasher is stuck on spin cycle will not do full cycle
  • CHRISTINE tAYLOR Jan 19, 2013
    Very stressed but obviously intended to say rinse thanks
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Spin cycle hey .thats some dish washer
Posted on Jan 18, 2013
  • 2 more comments
  •  dean
    dean Jan 20, 2013
    it most likely be thermostat bepends wat disher u got
  • CHRISTINE tAYLOR Jan 20, 2013
    BOSCH TYPE S9J51B 5 years old
  •  dean
    dean Jan 21, 2013
    YEP THERMOSTATE ,BLOCKED PUMP ,ELEMENT ,
  • CHRISTINE tAYLOR Jan 21, 2013
    Thank you .Is it a big ie expensive job to fix?
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
Dishwasher was fine till i put it on a full cycle then it went bang twice ..what as gone ?
If your Dishwasher is stuck in a cycle check the following
Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/control electronic. Use the VOM
Apr 05, 2013 | Dishwashers
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
Feb 13, 2010 | Bosch Dishwashers
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
Bottom drawer stuck on 12 min cycle(rinse only)
Turn power OFF at main power point, then
Turn power ON.
Check that the "ECO" button is no glowing.
Good Luck!
Feb 13, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Not full cycle
Check the board for burned spots.
Dec 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher
Check your float in the front left corner it may be stuck in the up position and making the dishwasher think is is full of water already.
Oct 29, 2007 | GE Profile PDW8000G Built-in Dishwasher
Machine runs through cycle but does not wash dishes
It sound like a pump issue. The pump is attached to the motor and forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. Look if the pump's impeller (a round plastic fan blade-type of device) spins around. In case it doesn't spin, look if it doesn't blocked or stuck from any other reason. Good luck
Aug 21, 2007 | GE 24 in. GSD3400G Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
