NEC laptop will not boot from disk or USB
I recently purchased a Japanese manufactured NEC LL750/J laptop while in Japan. Because the Windows 8 that came installed was somewhat in Japanese (even after you chose English there are many instances where something pops up in Japanese) and so I wanted to perform a clean install of Windows 8. I paid for and purchased Windows 8 Pro. I downloaded the iso file onto both a DVD as well as USB. I then set the BIOS to English and the boot order to CD/DVD first and then USB and then HDD. The NEC laptop just skips the disk and USB and starts Windows 8. I attempted to use a Windows 7 iso boot disc that know works fine and again it skips the disc and starts Windows 8. I was concidering purchasing Windows 8 OEM from the store and seeing if the OEM disc would work. But, I already feel burned bad enough having paid for Windows 8 Pro. I don't want to purchase Windows 8 Pro again only to find the problem lies somewhere with NEC BIOS settings. Any suggestions would be greatly appreciated, Michael Note: I have installed Windows 7 and downloaded software etc.. but I'm not that experienced with computer BIOS other than to set the boot order.
    New Friend:
  • 3 Answers
Set the BIOS to default settings , then change the boot order to boot from DVD ,see if this works .
Posted on Jan 20, 2013
  • 59 Answers
Just make sure ISO files or DVD you are using to boot with are actually bootable disc for OS ,as for USB booting ,you will need to turn on usb boot on the bios and software needs to be USB software.
and I am not talking about boot order that you have already selected.
check windows 8 software on anther machine and see if you can boot with it
Posted on Jan 18, 2013
  • Michael Jan 19, 2013
    I checked the Windows 8 Pro iso disc on another machine and it did begin the boot process (ie: 'press any key to continue...' after which the Windows 8 logo was displayed and eventually it started the installation process at which point I stopped and took the disc out). So it seems like the iso DVD is fine. There seems to be something going on with the NEC not reading the disc? Even when I put a Windows 7 Pro recovery iso disc into the NEC laptop it bypasses the option to boot off the disk and loads the Windows 8 installed OS. Any ideas?
4 Suggested Answers
McIndia
  • 131 Answers
SOURCE: Non-system disk or disk error - Remove disks or other media.
enable the option to check other boot devices, it should be the next option after the third boot device, also select the first device as USB DVD/CD
Posted on Jan 09, 2008
YourTech
  • 63 Answers
SOURCE: Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Posted on Aug 26, 2008
  • 1481 Answers
SOURCE: my laptop won't boot from cd
if u can boot from CD rom without ur HD then ur booting is OK. BIOS has nothing to do with ur HD booting.....it's just that the machine starts from BIOS 1st...then looks for the HDD to load the Win boot files..else it goes to CD rom for the boot files...and so on...
check that the boot from HDD sequence is not disabled in BIOS.
keep this boot seq
1 CD ROM
2 Floppy
3 HDD
4 USB HD
try this...1st
disable all 1 to 3 in above seq
connect a USB cd rom drive or a USB pen drive
ensure that ur Win disk is either in the USB CD rom drive or Win install files(copy of Win CD) are in a USB pen drive check if it boots from the pen drive....
after you boot....
connect your HDD now check if it can recognise the HD....else we can work on plan B
Posted on Dec 29, 2009
NEC Xp Home premium reformat and change the system to english from japanese
Possibly the drive is dead or the screen is no good any more.Try going back in Bios and change language.If it doesn't boot up possibly the drive or monitor is no good.If the laptop has a vga or hdmi connection you could try hooking it up to a TV or another monitor to see if it will boot up past the xp logo to test if the monitor is really broken or no good.
Sep 05, 2015 | NEC k 3800 mAh (OP57074402) for NEC LaVie...
How do I boot from a usb on a nec versa lx laptop?
Go to the store and purchase a good copy of Windows XP and install it from a disk. In the BIOS you should have the option of booting from external devices as a alternative as well. This would mean USB or any plug and play drive. Make sure it is set to boot to this fist boot. Really I would just go and get a copy of Windows XP it should be relatively cheap now since there is no real support or at least it is dying out or has died for support updates. If you can purchase the original boot and software for your computer from the factory as well.
I would also strongly suggest you take it in to the pro and have them do it less hassle for you if you have not done this a lot.
Jul 24, 2012 | NEC Versa LX Notebook
NEC LAVIE LL750/8 DRIVERS
I ask the driver to install laptop nec LL750 / 8
Aug 15, 2011 | NEC Computers & Internet
I need driver sound of laptop NEC Lavie ll750/c helpme please
You can download drivers from the NEC WEB site. Please clickon this link and select your model computer/notebook and the Windows XP orVista drivers you require :-. www.nec.com/global/support/downloads/index.html
Mar 03, 2011 | NEC LaVie RX Notebook
Opps reformated my hdd on my nec model LaVie model LL750/J
what exactly do you need to do? you formatted so are you going to reinstall windows? if so you will need a restore CD or a OEM or retail copy of windows, plus your drivers specific to that model. I believe that you can search for services on the web that will translate entire websites by entering the sites address.
you can also search other online databases for drivers too.
Apr 16, 2009 | NEC LaVie RX Notebook
Download drver for nec la vie ll750/b
go to nec wesite and download driver for you model laptop
Mar 30, 2009 | NEC LaVie RX Notebook
How can download Nec lavie LL750/7 network card. serial number: MFXHP GDT7J H8M88 4XKTF Q7RBW
my laptop as a sound problem i need to download driver for nec la vie ll750/b
Feb 26, 2009 | NEC Computers & Internet
A nec lavie ll750 notebook, no graphic driver, modem driver.
need to get the drivers from the web and put on a disk then take it to your pc
Oct 05, 2008 | Computers & Internet
Audio Devices
no sound when i reformat my loptop lavie ll750ad
Feb 14, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
844 people viewed this question
David Payne
David Payne
