Question about NetGear WGR614 Router
Router (WGR614v7) does not get wireless signal
When I tried to install the router (WGR614v7) to m laptop (IBM) the router shows that it's online but it does not pick up a wireless signal
  • Anonymous Feb 02, 2009
    I have the exact same problem.
  • sticknmove91 Feb 14, 2009
    I have the same problem.
    Scholar:
  • 141 Answers
Call NETGEAR technical Support. If they cannot help try this http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Our netgear wgr614v7 54 mbps wireless router has gone bad acording to our net work service.They tested there modem,that had astrong signal.now here is whats happnen,there is no signal frm modem to wireless...
This guide gives you the directions for setting up wireless on the Netgear WGR614v7.
Basically enter the routers ip address (192.168.1.1) in your browser. If you router has default configurations, then enter the username as "admin" and the password as "password." Navigate to "wireless settings" and then on that page you configure your network.
Jun 13, 2011 | NetGear WGR614 54 Mbps Wireless Router -...
How do I resolve my internet port light being amber on my wgr614v7 netgear router
Recommend that you go one step at a time.
1) unplug the wireless router.
2) reset your Cable modem or DSL modem. Wait until the lights show the Wide area network or WAN is working correctly before applying power to the Netgear wireless router.
3) After a minute or so, its signals should change from amber to bright green.
Repeat if necessary. If this doesn't provide the connectivity that you need, a call to your Internet Service provider may be necessary.
Sep 06, 2010 | NetGear WGR614 Wireless Router
Netgear WGR614v7 Wireless Router what do i need to use google,com
Search for wireless networks from ur laptop. u will find ur wireless router gets listed. Select it and click on connect. Your router assigns an ip to ur laptop by means of dhcp. Thats it u get connected to internet. ensure whether ur phone line is connected to rj-11 port of ur wireless router
Jul 21, 2010 | NetGear WGR614 Wireless Router
I can not connect to internet through my Netgear model WGR614v7. I started loosing connection through the wireless adapter & tried to refigure router & now I can't get connection unless pc is...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
May 17, 2010 | NetGear WGR614 Wireless Router
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
Can't connect a laptop wireless to WRT150N
What you can do is remove the wireless connection profile that is saved and create a new one. Go to wireless connection properties and create a new wireless profile. If that doesn't work, what you can try is change the wireless channel of your router to Standard Mode using channel 11 the power cycle the router.
Jan 13, 2009 | Linksys Wireless-N WRT150N Router
Port forwording
Follow the steps in this simple tutorial:
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614v7/Flatout_2.htm
Jan 08, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I HAVE A DELL COMPUTER, AND A LYNKSYS MODEM AND ROUTER. I HAVE TRYED SEVERAL TIMES TO GET THE ROUTER TO WORK SO I CAN USE MY IBM T40 LAPTOP, WIRELESSLY. EACH TIME MY INTERNET ACCESS ON THE DELL IS TURNED...
sounds to me like u r running the dell in the usb, and it has to be on for the ibm to work, or you have a dual ip addressing problem, which is a negative to the ibm when the dell is off.
My son has a IBM think pad as well, and when he uses the Ibm with his linksys wireless router he has the same problem, or did until I addressed the dual ip address issue, which I had to change the Ip address on our netgear, and left his as was and changed the one from My Dell inspiron 8600, I suggest you go to the linksys web site and follow the re install of new drivers for your router and if possible upgrade. they have available w wireless handing software program available to linksys customers as a trial you can download called NETMAGIC which also works quite well, and your able to monitor your network and it usually works well, I've used it until I upgraded to my netgear wireless G router.
hope this info helps you out.
Jun 12, 2008 | Computers & Internet
Wireless signal inconsitent; sometimes cuts out
If you are able to, take the the linksys card out of that IBM r50 and install it on another one of your laptops.If you get a great signal you know the card is good but if you move that card to another laptop and have the same problem you will have to replace the wireless card.If other laptops will not accept that card you can purchase a new Lynksys wireless usb adapter and see if that solves your problem.Those usb wireless adapters only cost about $35.Another way to seperate the problem would be to see if the IBM R50 will access any other wireless network with more signal strength.take your laptop to a public wireless connection(mcdonalds star bucks) any if you get a good signal than your problem is with your router.RATE ME IF THIS HELPS....Good LUCK!
Nov 17, 2007 | IBM Refurbished THINKPAD R50 - P M1.5GHZ...
NetGear WGR614 Router Logo
172 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
