Question about Dell OptiPlex GX280 PC Desktop
Gx280 powers up but no boot cpu fan runs out of control
Motherboard receives power, but nothing else comes up. The diagnostic lights will not illuminate.
  • Wes Ledbetter Jan 18, 2013
    Tried that... Same result... Solid amber power light... no diagnostic lights in the back... CPU fan revs up to warp speed
    Sergeant:
  • 248 Answers
Usually faulty ram chip / chips. Check that they are making good connection first.
Posted on Jan 18, 2013
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
SOURCE: Dell GX280 no display
I solved this on a Dell GX280 by removing the CPU and then reseating it in the socket. Also cleaned cpu and heatsink and applied new thermal compound.
Posted on Nov 01, 2008
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
SOURCE: Dell Optiplex GX280 -ABC LIGHTS LIT UP IN BACK USB-HIGH FAN SPEED
system halted my pc help
Posted on Feb 25, 2010
SOURCE: problem withe dell gx280 fan and display
I had exactly this problem on an Optiplex GX 280.
I replaced 1 stick of ram, and everything was happy.
Posted on Jun 03, 2010
I had the same thing happen on my Dell. I found the processor was bad,
Jan 18, 2013 | Dell OptiPlex GX280 PC Desktop
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
As soon as I install the lan drivers on my gx280 it goes off and the cpu fan speeds up to full speed, without these drivers it would work fine all day without internet connection of course.
Try running diagnostics on yourcomputer to see if you have a hardware problem. You should have a CD that camewith the computer that has "Diagnostics and Utilities" listed undercontents. Boot form this CD and run the extended diagnostics.
If you don't have the CD you can go to www.support.dell.com and select "Drivers and Downloads". Enterthe "service tag" (serial number) of the computer. You can then download"Diagnostics" .
To boot from a CD disk, power on your computer and tap the key to bringyou to the "One time boot menu". Insert the CD into the top CD/DVD drive andthen select "Boot from CD/DVD" and hit key. Select the "Runthe 32 Bit Dell Diagnostics.
If all tests pass then reload OS ( Operating Software ).
Jun 19, 2011 | Dell OptiPlex GX280 PC Desktop
Massive noise, now unable to access computer at all. constant amber light, not moving to next stage, nothing on screen, several thermal events previous to it blocking my access
Noise is most likely CPU Fan racing. Fault is most likely motherboard failure (Solid Amber power LED is usually MB and thermal events could be associated) Replace the motherboard
Feb 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Sep 30, 2008 | Dell OptiPlex GX280 PC Desktop
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
